Washer fluid setup
Old Jul 12, 2017 | 04:17 PM
lunar68's Avatar
lunar68
Washer fluid setup
Found this little fella dangling way down my inner wheel well. Figured it's probably the washer fluid motor. How do I get this setup like it should be? There's no fluid bag so I'll have to get one of those somewhere.
Old Jul 12, 2017 | 04:28 PM
JEFFFAFA's Avatar
JEFFFAFA
1st test it and make sure it pumps water. Then go to www.dennis-carpenter.com.
Windshield Washer Reservoir
MakeModelBody StyleNotesYearFordBroncoU-Series- 1968-70 FordT-Bird-- 1970 FordTruckF-Series- 1968-70
Our Low Price:$24.95 ea.
1968 - 70
C8TZ-17618-A
More Quality Products
Windshield Wiper Washer Pump
C8SZ-17664-A
$39.95
Old Jul 12, 2017 | 04:39 PM
lunar68's Avatar
lunar68
I'd like to keep it factory if possible. Anybody have a pic of the correct setup?
And yes the motor works.
Old Jul 12, 2017 | 06:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by JEFFFAFA
Lotsa luck installing this puppy! I don't know how Ford did it, but most people have an awful time trying to figure out how to install it in the reservoir.
Look at this parts catalog pic of the little charmer and its associated parts: Illustration Section 175, page 4.
Personally, I'd use the 1971/79 F100/350 & 1978/79 Bronco reservoir (D1TZ-17618-B-reproduced) and its pump.
The pump is EZ to install as its retained by a clip.
EOAZ-17664-A (replaced C9AZ-17664-A) .. Windshield Washer Pump (Motorcraft WG-30) / Available from Ford & auto parts stores, because...
Besides 1971/89 F100/350 & 1978/91 Bronco, this pump was also installed in a gazillion different 1969/90's FoMoCo Passenger Cars.
Old Jul 12, 2017 | 09:37 PM
pchelp's Avatar
pchelp
Hey Number, how are the squirters activated ?
Old Jul 13, 2017 | 01:12 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by pchelp
Hey Number, how is the squirters activated ?
... water pressure.
Or do you mean how is the pump activated?
Old Jul 13, 2017 | 01:18 PM
pchelp's Avatar
pchelp
Originally Posted by HIO Silver
... water pressure.
Should there be a button or toggle ?
Old Jul 13, 2017 | 01:34 PM
lunar68's Avatar
lunar68
Pull the washer ****.
Old Jul 13, 2017 | 02:31 PM
pchelp's Avatar
pchelp
Ok thank you lunar, twist for speed and pull for washers
Old Jul 14, 2017 | 06:44 AM
DisneysPatB's Avatar
DisneysPatB
It's not push for washer?
Old Jul 14, 2017 | 08:27 AM
pchelp's Avatar
pchelp
I bet there is someone with a OEM working one that can confirm
Old Jul 14, 2017 | 08:52 AM
lunar68's Avatar
lunar68
Mine goes when I pull the ****.
Old Jul 14, 2017 | 08:56 AM
pchelp's Avatar
pchelp
Thanks lunar, just for the record this is on a 68' correct?
Old Jul 14, 2017 | 09:39 AM
NumberDummy
C8UZ-17A553-A .. 2 Speed Windshield Wiper/Washer Switch (Motorcraft SW-869) / Obsolete ~ 1,000+ available NOS
1968/72 F100/750 / 1969 Econoline before serial number E10,001.
Old Jul 14, 2017 | 02:42 PM
lunar68's Avatar
lunar68
Yeah, mines a 68.
