Quick question about turbo feed line
Old Jul 11, 2017 | 07:27 PM
VictorwithaC's Avatar
VictorwithaC
So I have an '03 6.0 and its got a little leak on the I'm hoping turbo drain tube. I havent updated the drain or feed so i figure now would be a good time to do them. Now I see this kit http://ktperformance.net/i-16076187-ford-motorcraftturbo-oil-line-update-kit-ford-2003-10-6-0l-power-stroke-diesel-drain-line-6c3z-9t515-a-feed-line-3c3z-9t516-a.html?gclid=Cj0KEQjw7pHLBRDqs-X8hZ3Mgp0BEiQAXIo9rhMOUrkQObBiJj5aUJectZvJHHn_aZ9B PbtqCTY3W7EaAqlO8P8HAQ but it mentions needing an updated oil filter base if before a certain date in 03. How do I know if I need that? And should I do anything else to the turbo while its out? I don't have any issues with it now but since its out ya know.
Old Jul 11, 2017 | 07:33 PM
Yahiko's Avatar
Yahiko
Your going to have to get at the block S/N on the back side below the head
on the drivers side. Maybe if you still have the original FICM you could pull
the S/N from there but not sure I would trust that.
I would think one other option would be to fins someone that has a later
build date engine that has replaced the oil feed tube and see if the O-ring
boss fits on your engine.
Old Jul 11, 2017 | 09:01 PM
VictorwithaC
I guess for now I will just replace the drain tube. Wish I had known id have taken a picture of the number when I had the heads off. Thanks for the reply though.
Old Jul 11, 2017 | 09:12 PM
TooManyToys.'s Avatar
TooManyToys.
Do you know the date your truck was assembled?
Old Jul 11, 2017 | 09:15 PM
m-chan68's Avatar
m-chan68
How does your oil supply line secure to the oil cooler base? Is it secured via one 8mm bolt or is it the very early "quick connect/release" type connection? If it's the type secured via one 8mm bolt, then you can use that kit.
Old Jul 11, 2017 | 09:16 PM
VictorwithaC
if that is something I can find on the truck I will tell it to you but otherwise no clue. I know it is early 03 has the screw in shorter I believe standpipes
VictorwithaC
it is one 8mm bolt
Old Jul 11, 2017 | 09:45 PM
Yahiko's Avatar
Yahiko
Originally Posted by VictorwithaC
it is one 8mm bolt
M-CHAN68 Saves the day and some knuckle blood.
Thanks!
Old Jul 11, 2017 | 11:03 PM
chetspencer's Avatar
chetspencer
So my 2005 Turbo feed line has a braided steel portion and the brand new paper gasket is leaking on top of the turbo. Do I need to replace it with part# 3C3Z-9T516-A? Also any advice to dealing with the only frickin paper gasket in the whole engine from leaking. Should I use a sealant with it. Sorry to hijack.
Old Jul 11, 2017 | 11:51 PM
Yahiko's Avatar
Yahiko
A new gasket will solve the leak so long as the
surfaces are clean and the torque is correct.
Old Jul 12, 2017 | 06:41 AM
chetspencer
Thank you, I think I'm going to change out my braided hose version while I'm in there as well.
Old Jul 12, 2017 | 06:44 AM
VictorwithaC
can I ask what the negative to the braided hose?
Old Jul 12, 2017 | 06:47 AM
chetspencer
I thinks it restricts flow compared to the lastest version. Or it's just cost more for Ford to make.
Old Jul 12, 2017 | 06:51 AM
VictorwithaC
haha Probly It hurts to buy a $100 piece of pipe
Old Jul 12, 2017 | 03:45 PM
Yahiko's Avatar
Yahiko
The bart in the braid can collapse and restrict flow to the turbo.
Very hard on the turbo.
