noise
Old Jul 11, 2017 | 03:07 PM
27048's Avatar
27048
noise
I have a 1997 Ford F350 crew-cab 4x4, it is making a noise when the truck is idling and there is sight vibration in the steering wheel when starting off driving. The noise stops after changes to second gear. truck is an automatic.
Old Jul 12, 2017 | 02:42 PM
Jarrett Campbell's Avatar
Jarrett Campbell
What does the noise sound like? Is it coming from the engine compartment, trans, or rear end? How are all your fluids? Have you checked your trans fluid while the truck is up to temp and running?
Old Jul 13, 2017 | 09:18 AM
27048's Avatar
27048
Fluids are all fine, just changed oil to see if that could have been the trouble. The noise is coming from the engine compartment. The vibration appears to be getting worse. Transmission is changing smoothly. Noise sounds kinda like a bearing going bad.
Old Jul 13, 2017 | 09:27 AM
farmert's Avatar
farmert
Check the bearings on the belt idlers/tensioners. Also the vaccume pump, and AC clutch.
Old Jul 13, 2017 | 09:46 AM
27048's Avatar
27048
OK thanks, I will check those.
Old Jul 13, 2017 | 04:08 PM
echo95's Avatar
echo95
Almost sounds like a flex plate issue. I saw a thread a while ago where the noise would go away above 20 mph, and return below that speed. Hard to diagnose until it gets worse, but the inspection plate is easy to pull off, and you could be able to hear a sound difference if it is coming from that area.
chuck2629
2004 - 2008 F150
Nov 9, 2015 07:13 PM
MannyFord150
1997 - 2003 F150
Aug 29, 2013 10:43 PM
sammatt1
Aug 1, 2012 08:41 PM
nothercrash
17
Jan 13, 2011 06:00 PM
