overheated, will it live again?
Old Jul 10, 2017 | 02:49 PM
knottyrope's Avatar
knottyrope
it runs but for how long?
changed out rad and took it for a spin for 4.5 miles to store and a few min stopped there, one mile to pizza place with 15 minute wait and 4.5 miles back home. I noticed it was at the L on last 1/4 mile but no lights came on and didn't seem to be boiling when shut off. no running issue either. its wasn't that hot out either but maybe 75 out
Only a 1/2 gal of coolant lost and when removing top hose I could not blow into it which lead me to bottom hose issue of some sort.
I know it had the three caps removed but looks like it had two caps on the lower. I now have 4 caps in the box.
Old Jul 11, 2017 | 05:51 AM
Kingkong0192's Avatar
Kingkong0192
I believe once these Gauges read a certain temperature they peg themselves instantly to warn the operator of an issue. Don't quote me on that but it's ringing a bell for some reason.
If you overheated it bad you'd know it. Steam, coolant everywhere, coolant boiling, etc.
Old Jul 11, 2017 | 07:08 AM
oldbird1965's Avatar
oldbird1965
X2^^^ I've been up to the L a few times pulling hills, your alright. Did the engine temp light come on? I never knew there was one until I got mine hot.
Old Jul 11, 2017 | 08:05 AM
knottyrope's Avatar
knottyrope
The engine temp light didn't come one, no steam came out when I parked it,
I opened the hood to listen and no abnormal sounds like boiling.
Maybe I got lucky. I have driven it to work again today and runs fine so far after 60 miles.
Old Jul 11, 2017 | 01:15 PM
Bill97's Avatar
Bill97
Sounds like the OBS gods smiled on you. I'd feel pretty safe if I were you. MY brother boiled over his 6.0 towing a car home last summer. let it cool down and it's been fine ever since. He left it in Hot street while towing a trailer and it must have cooked itself. I'd say he got lucky. I also boiled over one of my boat engines when the impeller gave out. Couldn't even get in the bilge with all the steamed coolant coming out of the hatch. That also survived.
Old Jul 11, 2017 | 07:35 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
I had a 2001 Duramax that lost both head gaskets from me being dumb and wanting all the power when I was younger. I put 15,000 miles with head gasket issues towing 10k+ daily. I just drilled a hole in the coolant tank to it would vent the gas without pushing coolant out. The water pump suddenly went and I lost all coolant and overheated on the way to work one day. I finally replaced the head gaskets, neither head was warped, had valves done anyway, and replaced the water pump. It's still going 100k and two owners later. That was with aluminum 32v heads. I can only assume 16v iron heads would be even more resilient
Old Jul 11, 2017 | 11:07 PM
97-psd's Avatar
97-psd
I would say you are fine. If it didn't loose any coolant it didn't boil over it should be fine.
Old Jul 12, 2017 | 09:31 AM
knottyrope's Avatar
knottyrope
another 50 miles on it since yesterday, ill not worry about it so much now
Thanks for your posts
Old Sep 19, 2017 | 03:43 PM
knottyrope's Avatar
knottyrope
went for a 300 mile run to pick up a bed for a friend and no issues at the moment
Old Sep 19, 2017 | 06:00 PM
Hussler's Avatar
Hussler
Not that uncommon, no harm done. Last time I changed the water pump and fluid it was scary hot when that gauge went up, was sweating bullets. Probably just some air pockets in there. Just kept driving and watching , more miles than you did and the temp gauge came back down to normal.
bikerman2299
6.7L Power Stroke Diesel
Sep 15, 2025 11:50 AM
lauraj
Oct 13, 2017 04:24 PM
Jacob Duncan
Jun 26, 2014 11:57 PM
sd_mountaineer
Jul 20, 2011 11:17 PM
1buckeyefan
Feb 19, 2011 09:51 PM
