ways to troubleshoot ICP low code
Old Jul 10, 2017 | 08:18 AM
JoshC017's Avatar
JoshC017
Without having to buy a new sensor just to see if my old one is bad, how can I test it? Isn't there a reading I can give to you smart folks from my Torque app?
Will a low ICP cause the truck to lose fuel mileage and some performance as well? I've got a bad oil cooler and I'm not sure if that will also effect this issue.
Old Jul 10, 2017 | 08:46 AM
Ipstack's Avatar
Ipstack
I believe you can simply disconnect the IPC's electrical connector...and it will start and run as the IPC will use values that it has stored.....
Old Jul 10, 2017 | 09:23 AM
JoshC017's Avatar
JoshC017
i thought about doing that, just unplugging it to see what happens.
Old Jul 10, 2017 | 09:48 AM
WatsonR's Avatar
WatsonR
It should measure .18-.24 with KOEO and .80 or more at warm idle and to start.
It will run with it unplugged and use default numbers. If the connector is oil soaked, replace the sensor and the pigtail.
Set the Torque app to see ICP voltage. ICP is a commanded value, ICPV is actual values.
Old Jul 11, 2017 | 07:00 PM
JoshC017's Avatar
JoshC017
I got .9 volts at idle, not quite to operating temp. I was curious and at WOT I got 4.1 and I got .8 at warm idle.
TimBurns
Aug 15, 2019 10:03 PM
HighSilver
May 17, 2019 06:08 PM
BrokeLoser
15
May 20, 2015 06:15 AM
f150crewcab
May 23, 2014 07:12 PM
jjeffries
Jan 24, 2010 01:05 PM
