2001 excursion 0b1 vacume pump
Old Jul 9, 2017 | 01:20 PM
Heliredcat's Avatar
Heliredcat
I do not see a vacume pump on the passenger fenderwell im having the default a.c. to defrost when accelerating ,and 4x4 hubs not locking in auto ,, something is incorrect here ,, it looks stock,, I have located the 4x4 servo and the vac,chamber,tub. But cannot find a pump, what the hell?
Old Jul 9, 2017 | 02:17 PM
projectSHO89's Avatar
projectSHO89
Wrong forum.
Only diesels have the extra vacuum pump. You have a simple vacuum leak.
Old Jul 9, 2017 | 02:23 PM
Heliredcat's Avatar
Heliredcat
Simple vacume leak
Plugged the line to 4x4 hubs ,blew on red line air goes back into manifold,, sucked on black line to cab , can hear air and never seems to hold suction, also not sure about the red line that goes to back top of motor, looks like to intake valve type ?
Old Jul 9, 2017 | 02:28 PM
Heliredcat's Avatar
Heliredcat
Simple leak
3 red lines 1 to back motor untested, 1 to 4x4 solenoid,leaks is small 1 to storage box., seems to be the the line into cab or check valve on manifold? But don't see a check valve,
Old Jul 9, 2017 | 03:21 PM
Heliredcat's Avatar
Heliredcat
01 excursion vacume issue solved
Have the 6.8 gas version no vacume pump..
put a small bolt in the red line , pull vac line for the auto 4x4 engage servo, plugged off 4x4 auto and a.c. vent stayed on during acceleration all good just need to replace 4x4 auto servo located next to the battery, 760 636 9709 Dave thx for lookung
Skip1970
Dec 7, 2013 12:08 AM
hewett54
New Member Introductions
Aug 10, 2008 01:06 PM
Hervey Purcell
Mar 2, 2008 04:03 PM
omni
22
Sep 21, 2007 01:26 AM
Bruker
Nov 24, 2005 10:15 AM
