Moon Roof Problem
Old Jul 9, 2017 | 08:08 AM
Torvvald's Avatar
Torvvald
Moon Roof Problem
Here might be a new one for you... I have the single panel moon roof on my SD. I push the vent button one time and it opens at the back as designed but when I press that same button to close it, the moon roof closes and then pops right back up into the vent position. In order to close it completely, I have to press that button and hold it, watching until it closes tight and release the button. If I hold it a millisecond too long, it pops right back into the open vent position.
Any ideas?
Old Jul 9, 2017 | 11:31 AM
69cj's Avatar
69cj
The wife's ex-Lexus had the same problem. The dealer had to cycle it 3 times to relearn the computer. Ya, even windshield wipers these days have their own computer. The simple days of relays and pressure switches are a thing of the past.
Old Jul 9, 2017 | 02:34 PM
bushpilot's Avatar
bushpilot
you sure the roof isn't a one touch open? (mine is).
Old Jul 9, 2017 | 06:27 PM
mtnguy's Avatar
mtnguy
On my truck, I need to hit the close sunroof button to close the vent, directly in front of the vent button.
Old Jul 10, 2017 | 09:17 PM
Torvvald's Avatar
Torvvald
Yes, it's a one touch open, the vent button (2nd from the front) and one touch close, directly in front of the vent button. The one touch open for the vent is working fine, however, the one touch close, used when the vent is open, closes the vent and then it bounces right back into the open vent position. I have to hold the one touch close button until it's almost closed, release it and then press it again..... guess I better call my dealership.
Old Jul 20, 2017 | 09:24 PM
Torvvald's Avatar
Torvvald
Took it in to the dealer today. No problem fixing. Apparently the factory used a lube on the rubber seal that was somewhat tacky, making the closure a little tougher which kicked in the reverse safety feature. Seal cleaned, re-lubed and the process of re-learning completed. Working fine now...
mooch91
Aug 25, 2017 09:25 PM
Ozzie318
Sep 28, 2016 08:53 AM
alwaysfords41
Aug 13, 2013 10:52 PM
baja_stx
2004 - 2008 F150
17
Apr 27, 2004 11:17 AM
2004supacrewlariat
2004 - 2008 F150
Apr 6, 2004 04:04 AM
