Moonroof
Old Apr 2, 2004 | 09:58 AM
2004supacrewlariat's Avatar
2004supacrewlariat
Moonroof
Is there a better way to close this thing? I hold the button down until it closes snug, if I hold it too long it pops up and then goes through the cycle of opening and closing. I wish it had a one touch type of setup to close it.
Old Apr 2, 2004 | 10:23 AM
2004lariat's Avatar
2004lariat
I agree. I don't know why they have not put a bit more of a delay when closing. It is a bit of a pain is the a$$. But then again having the moonroof is worth the little pain.
Old Apr 2, 2004 | 12:11 PM
HoustonPerson's Avatar
HoustonPerson
Works for me
Interesting, mine does not have that problem. I just hold to close and thats it. It would be nice if it was automatic close. Mine won't tilt up unless I let go of the button and then hit again. So it works for me.
Old Apr 2, 2004 | 01:39 PM
CruelCrew's Avatar
CruelCrew
Once it closes, it should stay closed without cycling again. Mine does. You have to hit the button again to get it to open again.
The problem I have with the moonroof, is that the cover doesn't retract all the way.
Old Apr 2, 2004 | 03:10 PM
2004supacrewlariat
I agree. I wish the cover opened all the way while the glass is closed. If you open the moonroof all the way the shield will retract, but the top will start a racket when you drive with it fully opened.
Old Apr 2, 2004 | 03:31 PM
InboundFX4's Avatar
InboundFX4
Mine will shut and remain closed until I release the button and press it again. I do wish there was a way to close the moonroof and power slider with one touch.
Old Apr 5, 2004 | 11:33 AM
2004supacrewlariat
If I read these posts correctly, it sounds like there may be a problem with the switches? Mine sure dont work that way.
Old Apr 5, 2004 | 08:48 PM
Lariat4me2's Avatar
Lariat4me2
I can keep the button pushed for as long as I want and it will not move past the closed position until I release and push again. It sounds like you may have an issue.
Old Apr 6, 2004 | 04:04 AM
fordguy61mi's Avatar
fordguy61mi
Mine is a one touch auto open, but you have to hold the button down to close all the way, apparently so you can stop it in any position you want.
