Trailer Wiring Weirdness
Old Jul 13, 2017 | 09:16 AM
  #31
subford's Avatar
subford
Originally Posted by Cummings Guy
With the key on or off, hazards off, the controller light turns on when the brake switch is activated.
This normal.
With the key off, hazards on, the light does not turn on until the brake is pressed.
This is normal.
Key on, hazards on, controller light is on. Pull relay one, the light goes out until the brake is pressed then it turns on.
The only thing that could supply power to the light would be the PCM.
Unplug the PCM then if the pulling the relay does not effect it I would say bad PCM.
Old Jul 13, 2017 | 10:35 AM
  #32
Cummings Guy's Avatar
Cummings Guy
I have to walk away from this for now. It has taken too much of my time and I am behind on other projects. I wish I never noticed this.
If I take it up again, I'll post. Thanks again,subford, for all the time that you put into this.
Old Jul 15, 2017 | 11:20 AM
  #33
Cummings Guy
Solution: barnyum17 was correct in post 18. This is "normal" for some vehicles. I consider it a factory defect.
Search "Pulse Preventer" and "cequent 20501".
You remember when I said that the factory wiring was not altered and there needs to be a diode somewhere?
Tow Ready 20501 Pulse Preventer (Tekonsha 2180-S) | American RV Company
Tekonsha - Pulse Preventer Click on "Install Instructions".
Old Jul 15, 2017 | 05:16 PM
  #34
subford's Avatar
subford
That "Pulse Preventer" will not help you.
As per the instructions it is for a 1989 -1991 Ford truck and you have a 1993.
The Multi-Function Switch is wired different in the 1989-1991 trucks and the Hazard switch does not disconnect the brake lamp circuit from the stop light switch.
In 1992 and newer OBS truck the Multi-Function Switch disconnects the brake lamp circuit from the stop light switch.
Old Jul 16, 2017 | 03:17 PM
  #35
Cummings Guy
Crap
I saw in the diagrams that you sent that it does disconnect the brake lamps. I tested this and id works. I also don't see any connection between 361 (IIRC) from relay 1 and the brake light/ flasher systems but there is.
My nephew tells me to forget about it. Good it is almost a challenge to fix it.
subford, from what you know should it be working like it is or should the hazards have no effect on the trailer brake power?
Old Jul 16, 2017 | 04:16 PM
  #36
subford's Avatar
subford
The hazards should have no effect on the trailer brake power.
I just took two Multi-function Switches apart and cleaned them so they work right and both had no connection from the brake light switch contacts to the lamp circuits contacts when the hazards was in the on position. But they did have connection with the hazards off. I took them apart because the were open to tests and had green corrosion on the contacts before I cleaned them.
Old Jul 16, 2017 | 08:52 PM
  #37
Cummings Guy
What did you use for lubricant?
Old Jul 17, 2017 | 07:51 AM
  #38
subford's Avatar
subford
After I cleaned the contact surface with scotch brite pads then I used dielectric grease.
Then wiped the grease off and put the switch back to together.
Tried contact cleaner first but had no luck cleaning the contact surface.
Old Jul 17, 2017 | 09:36 AM
  #39
Cummings Guy
I have never had success with contact cleaner except on potentiometers in stereos. Rubbing alcohol works better. Apply it with a syringe and a small diameter needle.
I don't get it: you put the grease on then wiped it off? You ever loose a spring taking things apart?
Old Jul 17, 2017 | 09:57 AM
  #40
subford's Avatar
subford
When I wiped it off it left a small film on the contact surface.
No but one spring jumped out when I dropped a part of the switch and I could not come up with where it came from so I took the second switch apart to find out where it went.
Old Jul 17, 2017 | 01:53 PM
  #41
Cummings Guy
I have a theory on what happens to small parts that disappear. There are miniature worm holes all around us. The part hits our end of the worm hole and is whisked off to somewhere else. Do you ever get a sudden sharp pain somewhere on your body that you can't explain and it just as suddenly goes away? That is because your body just made contact with the worm hole.
There is someone somewhere that is finding all these little parts showing up and says where the hell is all this stuff coming from?
Old Oct 27, 2017 | 12:39 PM
  #42
Cummings Guy
I know where the other end of the worm hole is: My work bench!
Old Oct 28, 2017 | 12:42 AM
  #43
ifrythings's Avatar
ifrythings
By any chance is your 3rd high point brake light burnt out? If that bulb is burnt out your brake controller will get turned on by the pcm as there is no load on the brake wire when the hazards are turned on.
Old Oct 28, 2017 | 01:47 AM
  #44
Cummings Guy
My truck does not have a high mounted brake light. I even removed the lens for the light that turns on with the inside lights to make sure that it did not share the same housing.
dsager01
Mar 6, 2019 09:51 AM
mikepo
Feb 7, 2016 09:48 AM
dezertdirt
Electrical Systems/Wiring
Aug 29, 2012 01:32 AM
liljase
Dec 6, 2004 12:05 AM
eric664
All Things Towing
Mar 31, 2003 09:41 PM
