trans not shifting
Old Jul 8, 2017 | 12:48 AM
guyno96's Avatar
guyno96
trans not shifting
ok so i have a 96 f-250 with a 7.3 that will not shift out of first gear but if i but it in second gear with the shifter it will up shift to second gear but when you go back to drive it goes back to first gear i am at a loss here i have replaced the trans with one that is known to be good out of a 96 i have replaced the pcm my speedometer is working so i dont know what to do next any ideas thanks
Old Jul 8, 2017 | 06:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Get the codes read. Auto parts stores cannot read these codes, you need either a good independent shop or a Ford dealer.
Old Jul 8, 2017 | 09:51 AM
mcali2's Avatar
mcali2
Mark, what is the maximum temp the trans can take? My gauge said 220 on a long hill tow the trans warning light flashed due to my spedo shorting out i believe. I took it to a shop and they said 220 is too hot but there was not a over heat code. my temp sending unit was also mounted near the trans cooler and radiator so it can be getting radiant heat from that too. I will be moving it to the trans pan.
Old Jul 8, 2017 | 06:27 PM
Mark Kovalsky
There was no overheat code because 220°F is at the upper end of normal temperatures. You can run at 220°F all day long without hurting the trans.
Mounting the temp sender near the radiator and cooler makes it just about useless. Mount it in the test port on the driver's side of the trans to get useful information.
I don't know the max that the trans can take. I had one that ran hot enough to melt the solder out of the solenoids, and it still worked.
Solder melts at 450°F. Let that sink in for a while.
Old Jul 9, 2017 | 02:50 PM
mcali2's Avatar
mcali2
Thanks mark. I will go look for that test port.
Carnes99
Dec 21, 2019 06:56 AM
Bigblockboy
Apr 22, 2016 10:05 PM
ChunderDownUnder
Mar 11, 2013 06:04 AM
VanisleF250
13
Mar 7, 2009 09:50 PM
