Paint Options
Old Jul 6, 2017 | 07:05 PM
Grimm13's Avatar
Grimm13
Paint Options
Hey everyone, I recently found out that my truck was a special order, and I just happen to have the original build sheet though it is in poor condition. There is no paint codes on the top of the paper where there is a space for colors, but there is a section on the bottom where a note is added about paint. The seat is in storage so this picture is the best I have currently. Is there a known list of paint codes to possibly decode the paint option my truck had, I know the truck has been repainted at least once. the floor boards when i removed the carpet are a dark metallic blue which looks similar to a more modern Ford color called Deep Wedgewood Blue. This is more out of curiosity vs. me wanting to restore the truck to 100% stock, that ship sailed awhile ago, I believe in restomoding as long as the modifications look near factory and period correct.
The current color is a grey, which I plan on painting the truck in a two tone green and white since I found a period correct fiberglass white topper. Trying to give it the appearance of a factory topper package.
Old Jul 7, 2017 | 08:33 AM
scott79's Avatar
scott79
Did you check the drivers side door (below door latch on back side of the door) for the factory warranty plate? It will have the color codes from the factory on it!
Nice truck!!
Old Jul 7, 2017 | 01:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Warranty Plate riveted to the left door face below the latch.
COLOR code stamped on the 2nd line of the Warranty Plate between the W.B. (wheelbase) and MODEL codes.
But, if there's no COLOR code, the truck was painted a non standard color, making it a Domestic Special Order.
DSO code stamped on the 3rd line-far right of the Warranty Plate.
If there's no COLOR code and the DSO code has 6 numbers, the truck was a Domestic Special Order.
Originally Posted by Grimm13
floor boards when I removed the carpet are dark metallic blue.
Might be this:
1973/79: COLOR code S = Bright Dark Blue Metallic.
Old Jul 7, 2017 | 01:51 PM
Grimm13's Avatar
Grimm13
I do know it is a DSO and it is from my area originally, I am from Prescott, AZ. I am the second owner of the truck and it was originally from Phoenix, the elderly gentleman who owned it basically, age took away his ability to drive. So I understand non standard color with a DSO, but on that build sheet there is a note about paint at the bottom which I will circle on a additional image.
Thank you for any help.
Grimm
Old Jul 7, 2017 | 02:02 PM
NumberDummy
martiauto.com may have the Domestic Special Order paint formula, because he has ALL the 1967/79 FoMoCo records.
Marti is located east of the Black Canyon Freeway in El Mirage, NW of Phoenix.
Old Jul 7, 2017 | 02:06 PM
Grimm13's Avatar
Grimm13
fantastic thank you.
Old Jul 7, 2017 | 09:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Marti Auto Works - Concourse Quality, Hobbyist Price
Old Jul 8, 2017 | 07:39 AM
77F350RangerSCS's Avatar
77F350RangerSCS
On your build sheet..... WT-2828 just so happens to be a paint code for a Ford color.
Ford code WT2828
A Ford special order Gray color.
By chance truck was already blue like cab floors and someone special ordered it gray and was factory re sprayed? I don't know if Ford ever did things like that but I have heard of other similar things done by GM for fleet orders etc.
Look how nice paint is around Warranty Plate and is under clear part of door sticker. Looks like it was painted gray before those were installed.
Old Jul 8, 2017 | 10:14 AM
deich's Avatar
deich
I think that blue interior color was common in custom trucks. I have a '79 f150 custom 4x4 in original exterior color with that blue interior color. When the PO resprayed he had the interior sprayed as well and its starting to peel off the dash.
I know I have seen that dark blue in at least one other custom truck on line with a different exterior.
John R. Thomas
Jan 3, 2024 08:04 AM
HAMS64
Jun 1, 2015 09:10 AM
lewistg
May 25, 2014 09:19 AM
882tank
Mar 12, 2014 11:47 PM
brider
Jun 29, 2006 08:07 PM
