Sagging front end
Old Jul 5, 2017 | 11:49 PM
cd4e's Avatar
cd4e
Sagging front end
I have a 96 F 250 super cab 4x4 with 5.8 engine. My front springs seem to be weak as the tires are noticeably tipped in at the top and my spring bump stops are very close to the springs. what is the best fix for this condition? the front is ttb.
Old Jul 6, 2017 | 04:45 AM
'89F2urd's Avatar
'89F2urd
What is the rake of your truck currently? In other words, how much would it take to lift the front to match the rear?
Old Jul 7, 2017 | 10:22 PM
cd4e's Avatar
cd4e
level
well it sits pretty level as there is a slide in truck camper on it right now. I have Firestone air bags on the back so I can level it out to some degree. I just don't like the look of the wheels tipping in and not much travel distance on the front suspension. Just returned from Alaska on a 11,00 mile month long trip. The roads up there need a truck with good suspension travel when you hit the frost blowouts in the road, they can be pretty rough.
Old Jul 10, 2017 | 10:33 AM
'89F2urd's Avatar
'89F2urd
If you can tolerate it, I'd recommend a 2.5" lift for what you want to do. If the camper stays on tge truck, and drops the rear an inch or two, I'd add a pad back there to make it level after the front lift is installed.
Old Jul 10, 2017 | 07:17 PM
250FOREVER's Avatar
250FOREVER
I put Monroe air shocks on my 87 with a ttb . It use to bottom out on large humps in the road like at an intersection . It also stopped it form dropping with the snow plow on it . I only had to put a sleeve in one end of the shock to mount them . They are they the same ones used for a 150 rear axel , extended and compressed lengths are allmost spot on . It did not lift it any noticeable amount though .
Old Jul 10, 2017 | 07:43 PM
phoskins's Avatar
phoskins
I could be totally off-base, but I think worn ball joints can cause your tires to be toe-out or toe-in, like you seem to describe.
Old Jul 10, 2017 | 08:46 PM
250FOREVER's Avatar
250FOREVER
Camber is what he described but yes all ball joints and bushings should be checked .
Old Jul 10, 2017 | 09:56 PM
cd4e's Avatar
cd4e
Thanks for the suggestions, I just had my ball joints checked by a good garage and he said they were good and tight yet. Not sure what I am going to do yet, will keep my options open for now.
Old Jul 11, 2017 | 08:10 AM
jas88's Avatar
jas88
Why not just replace the front springs?
Old Jul 11, 2017 | 11:57 AM
FordTruckfan89's Avatar
FordTruckfan89
Cheap and not too bad.
Old Jul 11, 2017 | 03:25 PM
Benztechnc's Avatar
Benztechnc
How does it sit without the Slide In Camper on it? Does it have a rake? does it still have the (negative) camber?
268Fords
Sep 16, 2016 07:21 AM
chris86924
Dec 26, 2013 02:01 PM
minnesotafisherman
21
Nov 6, 2012 11:57 AM
blacksoot25
15
Sep 8, 2010 01:51 PM
Squiggy
Nov 24, 2004 10:20 PM
