Eletrical short and under hood light
Old Jul 5, 2017 | 06:56 PM
mcali2's Avatar
mcali2
OK I have a short and fuse 8 blows. I have removed dome lights instrument cluster, light switch, buzzer was removed long time ago, I have checked the glovbox light and switch and I keep blowing fuses. I am looking for the under hood light but i cant find it. is there one and where would the switch and or light be? where is the wire to feed this light I cant find?
Old Jul 5, 2017 | 08:11 PM
oldbird1965's Avatar
oldbird1965
Its sorta in the center and to the right a little. Wire is probably hiding behind the hood insulation if its been taken off.
Old Jul 5, 2017 | 10:15 PM
madpogue's Avatar
madpogue
It's actually on the LEFT side under the hood; IIRC the wire runs up along side the driver's side hinge, and there's a disconnect just before the hinge. Personally, I would recommend removing the light and taking it to your local hazardous material ("clean sweep") facility. The switch is a little blob of mercury inside a bulb; when the hood angles up, the mercury flows to where it closes the contacts to close the circuit.
Old Jul 5, 2017 | 10:56 PM
mcali2's Avatar
mcali2
I cant find it.. it must have been removed. I wish i knew where it plugged into the harness. I need to be sure it is not shorting out. I have been cutting wires and blowing fuses trying to locate the short. My harness is unraveled all over and my truck looks like a bomb went off. WTF!!!!!!! oh im so tired of this. thanks. If someone has a photo of where the harness would connect to the hood harness that i dont have now that would be great.
Old Jul 6, 2017 | 09:58 AM
mcali2's Avatar
mcali2
Well I figure it just did not come with one. or everything was removed. I cant find a plug that is open to connect one either. There is an open grommet in the firewall but cant find a wire. I have been removing and cutting wires to try and figure out where the short is. All I know right now its not at any of the easy items to get at. behind the dash .....
Old Jul 6, 2017 | 11:36 AM
farmert's Avatar
farmert
Section 18-01: Wiring and Circuit Protection 1996 F-150, F-250, F-350, F-Super Duty Chassis Cab, Motorhome Chassis, and Bronco Workshop Manual
DESCRIPTION AND OPERATION
Fuse Junction Panel
Each vehicle has a fuse panel that contains most of the fuses used in the electrical system.
Location
The fuse panels for F-150, F-250, F-350, F-Super Duty Chassis and Bronco are located on the instrument panel behind an access door, left of the steering column. The location of the fuse panel for the Motorhome Stripped Chassis is up to the body builder. The fuse panel for these models is usually located under the instrument panel near the steering column.
Fuse Panel, F-150, F-250, F-350, F-Super Duty and Bronco
Item Part Number Description
1 14401 Wiring Assembly — Main
2 14401 Fuse Panel
3 14401 Wiring Assembly — Main
4 — Fuse (3 Amp) DI Diesel
5 14526 Circuit Breaker (20 Amp)
6 14A254 Fuse Panel Bracket
7 14526 Circuit Breaker (20 Amp)
8 13350 Turn Signal Flasher Assembly
9 N803876-S424 Screw
Content
The following circuit protection charts give the location and values of all the circuits containing fuses or circuit breakers.
Fuse Panel, F-Series and Bronco
Fuse Protection Amps Circuits Protected
1 30 Heater/A/C Blower
2 30 Wiper/Washer
3 3A Idle Switch (Diesel Only)
4 15 Warning Buzzer/Chime Module, Exterior Lamps, Instrument Illumination, Trailer Exterior Lamp Relay
5 10 Air Bag Restraint
6 15 A/C Clutch, Diesel Aux. Fuel Selector, a Remote Keyless Entry
7 15 Turn Lamps, Rear Window Defrost a
8 15 Courtesy/Dome/Cargo Lamps, Electric Outside Mirrors, Speedometer Memory, Warning Buzzer/Chime Module, Overhead Console (Bronco) Sun Visor Illumination (Bronco)
9 25 Power Point
10 4 Instrument Illumination
11 15 Radio, Radio Display Dim
12 20 C.B. Power Door Locks, Electronic Shift Motor 4WD, Power Lumbar, Tailgate Power Window, Key Switch a , Power Driver Seat (SuperCab Only)
13 15 Stop/Hazard Lamps, Anti-Lock Brake Module Memory Power (F-Series Only), Speed Control, Stop Sense for: Powertrain Control, Anti-Lock Brakes, Automatic Transmission Shift Interlock
14 20 C.B. Power Windows, Tailgate Power Window, Instrument Panel Switch a
15 20 Anti-Lock Brakes (F-Series Only)
16 15 Cigar Lighter, Data Link Connector
17 10 Warning Buzzer/Chime Module, Warning Indicators, Diesel Indicators a , Gauges, Tachometer, Transmission Control Switch
18 10 Electronic Shift Module 4WD, Speedometer, Air Bag Restraint, Automatic Transmission Shift Interlock, Automatic Day/Night Mirror Overhead Console (Bronco), APCM (Diesel)
a Indicates Diesel or Bronco functions only.
Fuse Panel, F-Super Duty Motorhome Chassis
Fuse Position Amps Circuits Protected
1 — Not Used
2 30 Windshield Wiper/Washer, Internal Wiper/Washer
3 — Not Used
4 15A Instrument Panel Warning Lamps, PSOM, Warning Chime
5 20A PSOM, Marker Lamps, Instrument Panel Lights Main Light Switch
6 10A Body Builder Accessory Feed (Accessory and Run)
7 15A Daytime Running Lamps, Turn Signal Lamp, Overdrive Cancel Switch, Brake Shift Interlock
8 15A Body Builder Accessory Feed (Run Only)
9 15 Hazard Lamps, Stoplamps, Brake Pressure Switch
10 — Not Used
11 — Not Used
12 — Not Used
13 5A Instrument Panel Illumination
14 5A Radio Feed
15 — Not Used
16 — Not Used
17 — Not Used
18 — Not Used
This is from my manual. Have you checked the cargo light connection by the 3rd brake light? I can't seem to get the pics of the fuse panel to copy.
Old Jul 6, 2017 | 01:39 PM
mcali2's Avatar
mcali2
I'm confused on fuse 8 and 18. My spedo will not turn on the Odometer is not on. Fuse 8 is blown. What does 18 do for the spedo?
Old Jul 6, 2017 | 09:14 PM
mcali2's Avatar
mcali2
Well I found the short. I also fried more wires in the process. My truck looks like hell now and it is torn apart. I had it put together with the bad section disconnected and my spedo did not come back on. could it be fried? I don't see how. Well I have new harness on order and new wire loom wrap.. In the process i did find about 3 more areas with exposed wires from cracking. at the door. Well at least I don't have to pay a shop. unless in the end i broke more than they would have by just knowing how to find it easier.
Jack118711
19
Jun 5, 2019 10:49 PM
CharlyG
Sep 2, 2016 08:48 PM
z31freakify
Nov 29, 2015 09:19 AM
mike L
Feb 23, 2006 07:42 PM
flaireside95
Sep 30, 2003 02:26 AM
