Fan Clutch
Old Sep 5, 2003 | 02:55 PM
jb666's Avatar
jb666
Fan Clutch
Hi Folks!
I have a 93 f-150 with a 4.9L I6.
I am trying to remove the fan clutch. I have tried 6 different places to find a special wrench for removing the clutch.. with no luck.
At auto value I found a wrench for up to 88 4.9's, but this is a little too small for the 93.
Is there actually a special tool made for this? And how does it work?
Any info would be appreciated, as I am going insane turning a small job into what will now be a two day job..
(Mostly driving to parts/tool stores)
Old Sep 5, 2003 | 03:48 PM
wtroger's Avatar
wtroger
Fan Clutch
I use a strap wrench to hold the pulley and Cresent wrench to remove the nut. Remeber the nut is left hand thread.
Old Sep 6, 2003 | 09:36 PM
byronbgs's Avatar
byronbgs
Fan Clutch
jb666 what is your truck doing that you need to change the clutch? I bought one to change to try to fix the temp rising when I'm at an intersection for a while. Good tip wtroger. I happen to have a strap wrench and will try your method.
Old Sep 7, 2003 | 01:24 AM
SaintITC's Avatar
SaintITC
Fan Clutch
Autozone lists having the Ford tool for this on their free tool rental sheet (just need a deposit), but the Autozone's near me didn't have it.
I removed one of the pulley bolts from the water pump, and bolted a long box end wrench onto the pulley so I could hold it. Then I think it was a 1-1/4" wrench to turn the nut on the clutch. Worked out fairly well.
Old Sep 7, 2003 | 02:57 AM
XR4TiSam's Avatar
XR4TiSam
Fan Clutch
Don't believe the Zone. The wrench they have is 38mm (IIRC), and the nut on the clutch is closer to 35mm. All you'll do with that wrench is round off your nut.
When my fan clutch went ****-up during the Road Trip From Hell, I went to a quickie oil-change place that had a mechanic out back, and he got it off for me in less than a minute. Of course, he had a HUGE fan-clutch tool set...
Old Sep 8, 2003 | 10:52 AM
jb666's Avatar
jb666
Fan Clutch
Thanks for the inpuit folks..
I ended up grinding a 36 mm (Older year I6) clutch wrench that I could find, down to 40mm for the job.
byronbgs - It was completely loose when i spun the fan by hand, with a fair amount of forward-back movement. (1/4inch at least)
What really gave it away though, was the sound change in the truck.
