vehicle speed sensor
Old Sep 5, 2003 | 09:08 AM
sicbpguy's Avatar
sicbpguy
Question vehicle speed sensor
I have an 88 f150 with the 4.9 straight six. I am getting an intermittant trouble code of 29 which is for the vehicle speed sensor. When I check the code manual, it says that it is found in the transmission. When I check my Haynes service manual there is nothing mentioned about it in the transmission section. Looking on this site I see a lot of people talking about the VSS on the rear diff. I know precisely where this is, but I am not sure if this is the one I should be concerned with. When I start up the Rear ABS light comes on and goes right off again as if there is no problem. Also, I have failed inspection for the rear brakes locking up. I have changed all lines, rotors, drums, springs, wheel cylinders, shoes, etc. (the brakes are brand new from the pedal out). Anyone have any thoughts?
Appreciate the reply.
Old Sep 5, 2003 | 03:25 PM
offroadford4x4's Avatar
offroadford4x4
Get a new sensor from the dealer for in the rear. They cost just under $19 and the part # F85Z-2L373-AB.
Old Sep 8, 2003 | 08:19 AM
sicbpguy's Avatar
sicbpguy
Thanks for the info. Do you know if this is something that might prevent my wheels from locking up?
Old Sep 8, 2003 | 10:58 AM
offroadford4x4
It may but I'm not positive
