2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Roof Rack
Old 07-05-2017, 03:28 PM
ALScott's Avatar
ALScott
ALScott is offline
Roof Rack
Does anybody have a roof rack on a 2017 with panoramic roof? I looked at Ford accessories online and they offer a Thule but say it's not compatible with the panoramic roof. Is it a weight issue or just someone opening it and hitting the rack.
Old 07-06-2017, 07:13 AM
troverman's Avatar
troverman
troverman is offline
I don't really have the answer. The front part of the moonroof is the only part that opens. It drops down and retracts below the level of the rear glass, so I don't think it would hit a roof rack. I'm guessing it has more to do with the mounting method.
Old 07-06-2017, 08:04 AM
amartz02's Avatar
amartz02
amartz02 is offline
Just mount it over the bed.
Old 07-06-2017, 12:21 PM
ALScott's Avatar
ALScott
ALScott is offline
I would love that but I am trying to figure out a way to carry kayaks while towing a travel trailer. I don't really want a bed rack because I want to be able to use the bed cover. I have seen the stake pocket racks that will work but it appears the kayak would hang off of that too far over the trailer/hitch area and create an issue in tight turns.
Old 07-06-2017, 02:13 PM
albertatyke's Avatar
albertatyke
albertatyke is offline
I'm also wanting to get a roof rack, I want to able to put kayaks up there whilst towing a 5th wheel
Old 07-06-2017, 02:15 PM
amartz02's Avatar
amartz02
amartz02 is offline
Thule's rack will work, it just comes with the following warning from their website fit guide:
45. Thule does not recommend opening, venting, or retracting the sunroof/moonroof/glass roof while the rack is mounted. Damage to the glass and/or opening mechanism can occur.
This solution has a maximum weight limit of 130 lbs.
Old 07-06-2017, 09:31 PM
DDT11's Avatar
DDT11
DDT11 is offline
I have the Tule system, same as for the F150. I carried two kayaks without trouble, but it does bend a lot in the middle.
Old 07-06-2017, 10:53 PM
e23barton's Avatar
e23barton
e23barton is offline
Would something like
this this
work for you?
Old 07-07-2017, 06:23 AM
alexleblanc's Avatar
alexleblanc
alexleblanc is offline
I ordered my truck specifically with no sunroof so I could use the roof rack while towing my fifth wheel. I have a Thule rack.
Old 07-07-2017, 08:53 AM
ALScott's Avatar
ALScott
ALScott is offline
Do you have the panoramic roof on your truck? What size and weight kayaks do you have?
But why did you order without the sunroof? What makes the roof rack more usable without the sunroof?
Old 07-07-2017, 08:58 AM
RugbyRef's Avatar
RugbyRef
RugbyRef is offline
Brilliant!!
Old 07-07-2017, 09:20 AM
Benny996's Avatar
Benny996
Benny996 is offline
Wow, that is what I'm looking for Rugby, nice set up. Do you have part numbers for that set-up? Thanks.
Old 07-07-2017, 09:28 AM
ALScott's Avatar
ALScott
ALScott is offline
Originally Posted by e23barton
Would something like this work for you?
It wouldn't because I could not use my bed cover with a rack like that. I have looked at them. USA Rack makes one that goes in the stake pockets that allows you to still use your bed cover. However, i would rather not have the kayaks hanging that far past the bed while towing. I think they might get in the way of tight turns. Plus I would have to store those things somewhere when not in use. Don't want them on the truck all the time. Not crazy about a roof rack but like that better.
Old 07-07-2017, 09:51 AM
jm-bc's Avatar
jm-bc
jm-bc is offline
I have posted pictures of my new rack on a related thread "Mounting Contractor/Ladder Rack – Bolt-on or Stake Pockets?"
The big kayak is 18" and the truck is CCSB. If I placed that kayak in the middle I would be fine on turns with my travel trailer.
I found the custom build price to be very competitive to off the shelf pricing considering the size of the rack.
Old 07-07-2017, 11:49 AM
RugbyRef's Avatar
RugbyRef
RugbyRef is offline
That's not my setup. Look up a few posts above mine. I was just commenting on his.
Tim
Quick Reply: Roof Rack
