Shift indicator bulb
Old Jul 5, 2017 | 01:22 PM
DisneysPatB's Avatar
DisneysPatB
Where does the bulb for the shift indicator go ( can't find an illustration), and what is the number?
Old Jul 5, 2017 | 01:29 PM
TeachNlive4ever's Avatar
TeachNlive4ever
There's not a shift indicator bulb on the bumps
Old Jul 5, 2017 | 01:34 PM
JEFFFAFA's Avatar
JEFFFAFA
Bumpside steering columns didn't have a shift indicator lamp. Now if by chance someone has put a Dentside column in your truck, there would be a bezel around the shift indicator. The bulb was a Industry number 1445. As I recall that bulb was mounted in the T/S switch.
Old Jul 5, 2017 | 02:07 PM
DisneysPatB
Thanks all.
Old Jul 5, 2017 | 07:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You have to pull the steering wheel to access it, as it fits into the T/S switch then pokes into the upper flange where the indicator dial and separate shroud are located.
The plastic pointer on 1973/77's slips into a slot in the shift collar.
1973 and later T/S switches have a **** that protrudes from the right side of the switch that operates the 4 way flashers.
starrider
Sep 6, 2010 09:15 AM
1979camperspecial
Jan 15, 2010 04:24 PM
disoletruck
Oct 4, 2009 04:59 PM
