88-96 Engine bolt ons....
Old Jul 5, 2017 | 09:05 AM
Number4's Avatar
Number4
Anyone know if fuel injection parts (intake etc...) will bolt onto the '79 460?
Parts off a FI 88-96 F250 etc.
I've seen a few donor vehicles where the engine is said to be locked up, figured it'd still have some value to it the FI parts would swap over.
Old Jul 5, 2017 | 09:22 AM
'77 Ranch Beater's Avatar
'77 Ranch Beater
If I recall correctly, there is something different between the FI heads and carb heads; port spacing or something that fouls up the swap. Then you have to consider the plethora of sensors, wires and computer you'll need to make it run correctly.
Can it be done? Of course, if you're willing to put for the effort. Keep in mind also that there isn't a lot out there for Mass Air 460 EFI equipment. Most were speed density and don't take kindly to enthusiastic HP additions.
t
Old Jul 5, 2017 | 09:32 AM
KULTULZ's Avatar
KULTULZ
Post
The 7.5L EFI LT Engine was modified by smaller runners in both heads and intake(s).
You would be better off (IMO) to buy an aftermarket 4V ALUM intake and use CFI (aftermarket) or have the manifold modified for MPFI. Personally, I would modify EEC-IV to control it with MAP.
Or, if you are cheap like me, a CFI throttle body/injector asm from a mid-eighties application.
Depends on what you want the engine to do.
Old Jul 5, 2017 | 10:14 AM
Number4's Avatar
Number4
Thanks, really just waiting on a decent donor, some nearby RV's with low miles. Wanting the entire engine, running, but started to wonder after seeing some of the part-out ads.
crfly
Jan 22, 2016 10:18 PM
83 dump truck
Sep 15, 2013 02:52 PM
atomicjoe23
Aug 18, 2010 09:37 PM
phantom rider
16
Mar 6, 2007 10:58 AM
69ragtop
Nov 17, 2005 09:49 AM
