Electronics technical question on 85 4.9 OBD-I
I have done a lot of research and figured out how to use the self test with a light to get codes from the OBD-I system. What I am curious about are the extra data pins on the OBD-I connector(pins 1 and 3). Does anyone know what data protocol those pins use? Is it some form of Serial such as UART? If so, what baud rate is it?
Another question I have is related to the later sequential fuel injected motors with distributor ignition. Is there some form of Cam position sensor in the distributor? If not how did the EEC-IV/V system know when to trigger each injector? A crank position sensor alone couldn't do it, because the computer couldn't know if the cylinder was on an intake stroke or a power stroke without knowing where the cam is.
I know these are weird questions, but I have some ideas for a couple of potentially fun projects.
Thank you ahead of time for your answers!
The computer used the dist to keep the injection timing and the ignition timing straight. I believe one of the teeth on the wheel down in the dist was wider than the others, and that's how it knew where it was in the firing cycle.
There is a wire leaving the ignition module which is the raw timing signal. It's called the PIP signal (Profile Ignition Pickup). This signal goes into the computer where it uses it for various things, and it also takes this signal and modifies the timing of it, and then sends it back to the ignition module on the dist. This is called the SPOUT signal, the one you have to disconnect to set the timing.
https://en.wikipedia.org/wiki/Intel_8061
