4.9L No Fire
Old Jul 3, 2017 | 12:00 PM
BWD444's Avatar
BWD444
4.9L No Fire
I swapped a 4.9l into a 1997 F-350 that had a 5.8L originally, my issue is the fuel injectors are not working. I did my homework and got the harness that was with the engine out of a 1995 F-150 and also got the correct PCM to go along with my E4OD tranny that is in the F-350. It has spark and 60 plus PSI fuel pressure in the rail and will run with starting fluid shot in the throttle body. Both vehicles came with OBD I so should be compatible there. I do not have 12v to the injectors and obviously the NOID light shows no pulse either. Could be a ground but not sure where to look or what else could cause this. I am so close to getting this running thanks for any and all help.
Brian
BWD444
Electrical Systems/Wiring
23
Jul 9, 2017 07:53 PM
BWD444
Jul 4, 2017 02:06 PM
BWD444
Jun 27, 2017 02:39 PM
Sablawn
Dec 21, 2015 10:28 AM
maxtor247
Jul 26, 2004 10:53 PM
