Troubleshooting a starter issue
But now I went to start the truck; the starter isn't doing anything, and I'm getting smoke coming from inside my dashboard. I thought it was the starter switch on the steering column, so i replaced that. Nothing. I tried replacing my starter just to see, and still nothing. Every time I hold the key on the start position, I get a little smoke coming out of the dash. I can't see wheere the smoke is coming from. WHAT IS THE PROBLEM!?!? I'm guessing now so any advice would be helpful. There might be something I didn't think about. Thanks
Once you find and fix the dash smoke I would replace ALL battery cables and don't tell me "they look good" as they can still be bad.
There is a post on how to check them do a search
sparking when jumping like you did is normal as the starter pulls a LOT OF AMPS!
if you go from batt posative to the small S lug what happens?
Dave - - - -
Start & Ignition - ???Gary's Garagemahal
What brand of starter solenoid did you buy? Was it name brand like MotorCraft or AC Delco? Or was it an offshore brand like Fling Dung?
The present fault of smoke under the dash means you've got a serious overcurrent in the starter control circuit. Don't worry about the big battery cables or the starter at the moment. It's the small wire from the ignition switch to the solenoid that's carrying too much current.
If you melted some insulation under the dash, I'm surprised fuse link M didn't open. See page 26 at the link above. There's no fuse in that circuit, just the fuse link.
The solenoid is the most likely culprit for overloading that circuit. It's basically a big electromagnet controlled by the ignition switch. That electromagnet in turn moves contacts that route power to the starter.
Try this for troubleshooting: Disconnect the big cable on the solenoid that runs to the starter. The starter obviously won't turn. Now turn the key to start. Listen for the clunk as the electromagnet in the solenoid gets powered. See if you still get the smoke.
You will still have to get under the dash to find the overloaded wire and replace it. But for now it's important to find and fix the cause.
If it is not safe you may let the last of the smoke out before the fire starts!
I find if the cables have too much resistance it will not pull the solenoid in all the way and it could the smoke solenoid.
I don't know how that could over tax the key start circuit, it just would not pull in the solenoid no?
Dave ----
