Unexpected Voltage at Starter Relay
Old Jul 3, 2017 | 12:19 AM
BGTerry's Avatar
BGTerry
Question Unexpected Voltage at Starter Relay
I have a 99 Expedition that has been parked for quite a while due to a Starter Relay and Battery Cable. I just replaced the Battery, Battery Cable Set and Starter Relay. It starts fine and seems to run normal, however, in trying to identity the trouble, I found 4 Volts (3.95) at the S terminal on the Starter Relay, even when the key is off.
This goes to 12 Volts when the Key is turned to Start and it does not (currently) seem to cause trouble, but I'm concerned that it could unexpectedly engage the starter while driving.
Is this normal?
Thank you
Old Jul 3, 2017 | 06:59 AM
projectSHO89's Avatar
projectSHO89
It's not a problem, don't worry about it.
kr98664
32
Aug 22, 2025 01:37 PM
frame30
13
Oct 9, 2012 11:21 AM
ducksoup
Apr 5, 2011 08:24 PM
GomerFackworth
Electrical Systems/Wiring
Sep 19, 2006 06:40 PM
pegasus58
Dec 11, 2005 11:05 AM
