Sponsored by: Real Truck
Question - 12V outlets in cab
Old Jul 2, 2017 | 07:11 AM
RA12726's Avatar
RA12726
Banned
Our 2012 F350 Lariat gets used almost exclusively for towing our fifth wheel (we're full-time RVers). The built-in navigation is not well suited to RV use, so plugged into the 12V outlets in the dash and center console (either with 12V plugs or USB adapters) are: 1) an RV GPS, 2) a dash cam, 3) the monitor for the rear view camera on the fifth wheel, and 4) the TPMS monitor [for both truck and trailer].
Since these outlets are live all the time - even when the truck is off - I have to unplug all these devices each time we stop so that there is not excessive drain on the batteries over the days to weeks we are in one place. Looking through the manual, I don't see where making these outlets switch on and off with the key is an option. Does anyone know a not-too-difficult way to convert these outlets to being on only when the key is on?
Thanks,
Rob
Old Jul 2, 2017 | 07:47 AM
Gas Guzlr's Avatar
Gas Guzlr
Short of cutting the feed wire and putting a switch in-line, you will not find an easier way.
If you have up-fitter switches just buy an add on 12v receptacle and put it on one of those switches.
Old Jul 2, 2017 | 01:20 PM
RA12726's Avatar
RA12726
Banned
There is a row of unused up-fitter switches. I'll look into taking the power leads and running them to one or two of those. Thanks!
Rob
Old Jul 2, 2017 | 01:37 PM
senix's Avatar
senix
upfitters is the way to go with this.
Old Jul 2, 2017 | 02:40 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Documentation on the Aux switches:
Old Jul 24, 2017 | 10:44 AM
RA12726's Avatar
RA12726
Banned
Easy solution:
https://www.amazon.com/gp/product/B06VTQDDQW/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B06VTQDDQW/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
The adapter has outlets for three 12V plugs and four USB ports. It's a cleaner solution than having wires still running down the side of the console to those power outlets and the plug for the adapter has a push-button on/off switch that I can use without unplugging anything.
Rob
Old Jul 25, 2017 | 12:47 AM
Dakar Dad's Avatar
Dakar Dad
I tapped into the Violet power wire going to the upfitter switches thru the harness that passes right past the area to power my 12v outlets.
Awhile ago I created this post.
It would really work well with the 3 port item in the previous post.
jniolon
20
Mar 23, 2017 10:49 PM
Trophy_23
Aug 29, 2016 08:43 PM
70 Bronco TX
18
Mar 9, 2012 12:38 AM
SlickYamaha
Mar 8, 2012 11:46 PM
lexustbs
6.7L Power Stroke Diesel
Dec 27, 2010 05:43 AM
