1990 E350 overdrive switch replacement
Old Jun 30, 2017 | 11:24 PM
Jim Webb's Avatar
Jim Webb
6th Gear
Looking to buy a camper van. The OD switch is broken (as in multiple pieces). Is the switch assembly still available from Ford parts counters? Found used ones online but would rather have new. Need to make a decision on this before the dealers open on Monday. If you know a part number that would be a plus. This is the dash mounted switch to the left of the steering column. TIA.
Old Jul 1, 2017 | 07:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I have no idea, but if not, the switch itself is nothing special. It is just a normally open momentary contact switch. Anywhere that sells electronic parts would have one of those for dirt cheap.
Old Jul 1, 2017 | 09:59 AM
annaleigh's Avatar
annaleigh
Can you describe what it looks like, does it have a light, is it rectangle shaped?
Scan through these pics..
https://www.google.com/search?q=1990...jhtdbQKTicwYM:
Here are some others, does it look like one of these? Often on ebay the parts might be listed for a Bronco or F series but and not E series but will fit..
http://www.ebay.ca/itm/87-91-FORD-F1...3D322554939701
1988-1991 Ford Bronco F150 OD Overdrive dash switch
http://www.ebay.ca/itm/1988-1991-For...3D302355280087
Old Jul 2, 2017 | 05:46 PM
vacuumbed's Avatar
vacuumbed
I am familiar with this switch. It is just to the left of the steering column and has an amber light. This is a dealer only item and it's not obsolete! Call your local Ford dealer parts department and ask for it.
Old Jul 3, 2017 | 12:17 AM
annaleigh's Avatar
annaleigh
Should be part number E9UZ-7G550-B
Old Jul 3, 2017 | 12:59 AM
vacuumbed's Avatar
vacuumbed
That's it!
Old Feb 1, 2018 | 09:33 PM
timbuctooCal's Avatar
timbuctooCal
obsolete switch,but....
Originally Posted by vacuumbed
That's it!
Got here a few months late and the od switch is obsolete
any switch for ford OD should work? Or any radio shck? or should I look somewhere else?
Old Feb 2, 2018 | 10:32 AM
Mark Kovalsky
Any momentary contact normally open switch will work.
Old Nov 9, 2022 | 10:37 AM
Jamesk6423's Avatar
Jamesk6423
4wd High
Switch from an 87-91 bronco would work. Same switch, slightly different mounting system. Van version has metal spring tabs on side, bronco version has two ears with screw holes and it screws in from the back. You can get creative with the mounting or transfer the new switch into the old switch housing (basically just need to reuse back half of the old switch housing).
Old Nov 10, 2022 | 08:22 AM
manicmechanic007's Avatar
manicmechanic007
Any trunk release or fuel door release switch you find at a junkyard would work
I would just plug that number into ebay and google and find a NOS switch (wrong)
ebay item # 185640848925 is a NOS F350 OD cancel switch seal similar to the one you need for your van
Be Spock and mind meld it into your van
It's a E9TZ-A in Houston free shipping 69.99
Old Nov 10, 2022 | 11:59 PM
timbuctooCal
Thanks manicmechanic007
Old Nov 11, 2022 | 12:01 AM
timbuctooCal
Thanks Jamesk6423;20623534
mattt181
19
Jun 12, 2023 12:06 PM
wharthog
Nov 9, 2017 09:18 AM
NICKSAN
Mar 26, 2017 01:19 PM
ExtrmZ
Oct 7, 2014 07:33 AM
BillyBob69
Mar 17, 2012 12:26 PM
