Transmission issues
Old Jun 28, 2017 | 05:27 PM
Tylerd's Avatar
Tylerd
Transmission issues
Hey guys I have a 91 f150, 302 with an aod which has been swapped from a 5.8 and e40d. I bought the truck like this. The truck doesn't seem to shift out of first. After doing some research I figured out that the tranny harness from the aod is different from the e40d. So my question is can I run the aod with the wiring harness and computer from an e40d with the push button manual over drive. Any advice would be great thanks guys
Old Jun 28, 2017 | 07:07 PM
Conanski's Avatar
Conanski
Yes you can put the AOD in there.. but you won't have any control over the trans because it is not computer controlled. You will need a TV cable and the throttle bracket for it and a specific 28oz/AOD specific flexplate as well, DO NOT use the flexplate on the E4OD or you will destroy the trans.
Old Jun 28, 2017 | 07:23 PM
Tylerd's Avatar
Tylerd
It has the tv cable and proper flex plate. I have adjusted the tv cable by taking slack out at full throttle. Seems to shift into 1st 2nd and d but always seems to be the same as first
Old Jun 29, 2017 | 02:24 PM
rla2005's Avatar
rla2005
Try taking a look at this video for the proper way to adjust the TV cable:
Old Jun 29, 2017 | 06:48 PM
Tylerd's Avatar
Tylerd
Thanks, I watched the video and tried the adjustment but still not shifting. I've been thinking about a stuck shift valve, or is it probably toast?
Old Jul 7, 2017 | 09:45 AM
rla2005's Avatar
rla2005
If the TV cable was not properly adjusted the transmission may be toast already. It's a critical adjustment....
reed1951
Jan 2, 2014 05:50 PM
gov2mod
13
Jun 29, 2011 09:26 AM
tired51
Mar 20, 2011 10:07 PM
88f150302
May 20, 2010 01:54 AM
gov2mod
1978 - 1996 Big Bronco
Sep 26, 2005 12:11 AM
