Random Questions
But no problem answering multiples either.
You've already got some good answers, but I'll add some more.
But wait for confirmation on that. I'm just spoutin' off.
Looking at your link, that chart seems to confirm what I'm gettin' at.
Never measured, but if you can't touch your hub it's too hot.
For example, I've run down I-5 here in CA at 75 mph in 85° heat and when pulling off the road and stopping, the hubs were barely warm in the front. A little warmer in the rear, but not so much I could not lay my hand comfortably on them.
This to me is the perfect scenario, but not the only acceptable one. Here the cooling air flowing over them was more than the heat generated.
Brakes have a huge effect on wheel bearing heat however (as was mentioned). So around town on a hot day when you're on and off the brakes a lot, the hub might be extremely warm. Still not enough to make you pull your hand away, but almost.
This is on a 4wd in my case. The 2wd might be similar, but with different parameters. I've felt some pretty hot hubs that were not failing, but it's not the best scenario to have long-term.
Is yours 2-wheel drive or 4? That usually makes a difference in your oil pan choices, but also makes a difference in how wheel bearings are adjusted in the front.
Having an F250 I'm assuming you have a full-floating rear end? Hah! That's another one of those things that "you had to be there" to know maybe. Or have you already run across that term?
If your rear axle has large, long hubs sticking out the center of the wheels with several bolts in a circle, that's an indicator of a full-floating rear end. If the ends of the axles are flat and do not stick out proud of the wheel center, it's a semi-floating rear end.
If you don't already know that, we can give a more full description of what that means.
How long have you had the truck? Long time or new owner?
Paul
got a Dana 60 full floating rear I'm going to be converting it over from drum to disc after I get it rebuilt
Oh and it's also a two-wheel drive
I've been looking at your debates you have on oils here
So far I'm leaning toward rotella 15-40
what oil are you guys using in the lower states that stay at cooking temperature????
I had a local shop that still does kingpins rebuild my entire front end. I got new springs, bushings, drag links, center links, etc., alignment and shocks on front and rear. I specified Moog parts. It was about 1200.00 total. I have zero tire wear in 40K miles or so. It also drives straight with no pulling or shake. I grease them regularly with the front end jacked up and then again when it's down. I'm kind of OCD when it comes to vehicle maintenance. I went with the Ford mechanics manual specs on setting the wheel bearings. It gave a torque range on the hub nut to set the bearings then back off some. My biggest issue with the truck was rear brakes. Make sure to change the fluid out to prevent corrosion. I just replaced my rear wheel cylinders due to small leaks because the insides had rusted.
What intake manifold should I get again this is a heavy torque build I've heard that a single plane is better for our blocks then a dual-plane what's your opinions and experiences
As far as the suspension goes, the ball joints are easier to change, but the king pins will give more warning before you get stranded. Life seems to often be a trade off. I've seen more disabled vehicles due to ball joint failures than king pin failures. If you're conscientious on maintenance, and don't do wild things while driving, probably neither will fail. A little grease will often keep things going.
Somehow I doubt that the Chevy & Ford rocker gaskets will interchange. They have different part numbers.
Thanks for raising the questions. Reading all the answers has been interesting.
Yeah through my research and looking at what other people have been running I've decided to go with the 15/40 Rotel. Has all the vitamins and minerals the truck needs
Yeah the valve covers I didn't know I just found them tucked away in the corner of the shop from some old mechanic time's going by
And I'm super OCD on the maintenance on all my vehicles so I decided to stay with the kingpins even though I probably wouldn't be able to fix them on the side of the road on a long road trip I probably wouldn't have any problems with them during the road trip without severe warning
This question is for rear axle braking
its a
Dana 60 full floater, 3.73
I have 31 inch tires on the rear
was wondering when I'm having it rebuilt would it behoove me any to have it stepped up to a larger pinion and/or ring gear
questions
how would that affect my mpg
how would that affect my towing ability on hills
how would that affect my top end
I don't plan on going any faster that 65-70 in the beast with or without a load
and I don't plan on towing anything heavier than 5000 lbs.
and finding the big rear pan pickup with tube is a bear also......
