How much DEF?
Old Jun 25, 2017 | 08:46 PM
Taebaker's Avatar
Taebaker
How much DEF?
I just had to add my first DEF to my 2016-F-250, and added one gallon. I have looked in my owners manual and no-where does it tell me the quantity that the DEF tank holds. My truck now tells me that the level is Okay.
Old Jun 25, 2017 | 08:57 PM
dirthawg's Avatar
dirthawg
Page 57 of the Diesel Supplement Manual.
Old Jun 26, 2017 | 09:32 AM
Deuce40s's Avatar
Deuce40s
Why did you have to add, and why did you only put in 1 gallon? I try to run it down to nearly empty before I add, that way I can stick almost 5 gallons in at once.
Do you have the DEF nozzle yet? If not, buy it.
Amazon Amazon
Old Jun 26, 2017 | 09:55 AM
djousma's Avatar
djousma
Capacity is about 5 gallons. If you got a message, what was it? Depending on the answer will dictate how much to put in. 1/2 will take approx. 2.5 gallons, 500 miles to go will take almost 5 gallons. Putting just a gallon in, unless that was all it would take is not enough to reset the sensors in the tank. If you got the "erroneous" 500 miles to E message, but the tank only took 1 gallon until full, that's a known issue where occasionally the computer gets confused on how much DEF is in the tank. I've had that a couple times on my 2016, not sure if anyone has seen that in the 2017's yet. that condition usually resets itself after a few trips out and about.
Old Jun 26, 2017 | 12:48 PM
camminich's Avatar
camminich
I have noticed running B20 will also trip the DEF sensor if you were already a little low. I think the truck just sprays more when running that stuff as even with the 500 indicator coming on I never put more than about 2.5 gallons in, vs the one time I did run it down to about 200 miles to go under normal diesel fuel and it took 4.2 gallons.
I'd 2nd that Ford DEF nozzle, it's a must have. I know many of the different brands include their own nozzle, but the Ford one works much better and doesn't spill. That way it doesn't look like someone whizzed down the side of your truck.
Old Jun 26, 2017 | 01:18 PM
frito1's Avatar
frito1
The Ford spout for the 2.5 gallon jugs is a good purchase. It lets you fill to the top without a spill. It fits other brands of DEF containers. Well worth the 6-8 bucks.
Amazon Amazon
Old Jun 26, 2017 | 01:29 PM
Taebaker's Avatar
Taebaker
Thanks Guys. This is my very first Diesel so I am a bit of a "Consciences Ignoramous" when it comes to my new truck. I was given a "DEF 1/2 full" notice by the truck and being one of those that likes to keep things topped off decided to put in a gallon. I used a funnel to put in the DEF and seemed to work just fine. I will certainly make a point of getting a spout however. This is the reason I joined this site, appreciate your help greatly.
Old Jun 26, 2017 | 03:05 PM
Deuce40s's Avatar
Deuce40s
I understand about wanting to top off. However, if you top off early on this system you will get false readings of quantity remaining. You have to run it down to the end to trip all the sensors.
Old Jun 26, 2017 | 04:08 PM
dirthawg's Avatar
dirthawg
You only added 1 gallon? Did you not purchase a 2.5 gallon box of DEF? If you got a warning that the DEF was low it might take more than a gallon to top it off. I had to fill my DEF after a 500 miles to empty warning at 2500 miles on the truck and it only took 2.4 gallons before it spilled out all over the side of the bed.
Old Jun 26, 2017 | 11:15 PM
Painted Horse's Avatar
Painted Horse
I have not bought a jug of DEF in almost a year. So many stations that now offer it at the pump. It's cheaper than buying in a jug, and I get the exact amount I need. Never have a jug with 2 quarts left in it.
I top off when ever I am at a station with DEF at the pump and I'm below 1/2 tank. Never had any problems with tank errors.
Old Jun 28, 2017 | 11:24 AM
ssunit1's Avatar
ssunit1
After numerous DEF jugs I had something strange happen when adding some this last time. My dash reading said I was under 1/2 full but not sure how much under. I got my jug of Blue DEF and starting filling the tank. With the jug almost empty the DEF tank overflowed. After checking a couple times to make sure I wasn't doing something wrong I reinserted the tube to empty the jug and found that the DEF tank was full.
Not sure how that happened if the dash reading told me I was under half in a 5 gal tank and I used a 2.5 gal jug.
Old Jun 28, 2017 | 02:04 PM
PROSTOCK's Avatar
PROSTOCK
You're not the only one in this same boat, so I thank you for this posting, cuz' I had no idea either, lol. Mine says it's under 1/2 and I have never added any since I bought it last month, so this is great info.
Old Oct 4, 2020 | 11:01 PM
Markdent73's Avatar
Markdent73
I have owned a 2013 F-250 with 6.7 since new. Under normal driving condition I don’t have to add DEF till my oil change light comes on between 7,500-8k miles Which at this time I would top it off. I have bought the Motorcraft DEF in the 1 gal and the 2.5gal and use the Funnel from ford. No problems! I currently have 116k mile and works as it should. It’s been the best truck I have ever owned!
babybober
Dec 21, 2017 12:49 PM
bulla
Oct 28, 2011 09:34 PM
KC8QVO
6.7L Power Stroke Diesel
21
Jun 21, 2011 06:10 PM
whporwil
6.4L Power Stroke Diesel
13
Oct 31, 2008 10:19 AM
jshumadine
Mar 16, 2008 07:29 PM
