active vs passive regen
Old Jun 25, 2017 | 06:03 PM
jeremy123's Avatar
jeremy123
I finally got the dealer to turn on my DPF gauge (I had to show them how), and I was all excited to see my filter was 85% full. This is my first diesel so I have never felt a regen before.
The truck has 1500 miles so I'm sure I have already went through some, just never noticed it. I got on the highway at 95% full, after a couple miles it went to 99% then...
I was really waiting for a loud sound and a bad smell, that never happened. Because I was watching it I did notice a sound, kike the truck was downshifting sound, but that was it. Was a lot more quiet than I thought it would be.
So of course I flipped over to my fuel gauge and sure enough MPG dropped to about 10. Finny thing was after about 5 min of the regen, my MPG went back up and I couldn't really tell I was in a regen anymore just by the MPG.
I flipped back over to my DPF screen and I was at like 80% and dropping, so I was still in regen, but again the MPG has settled around 16.
So when your on the highway, does it sometimes go into active then switch to passive when it gets hot enough?
Old Jun 25, 2017 | 06:56 PM
sdm300's Avatar
sdm300
On my 2010 6.4L, I could sometimes detect an active regen by a feeling a slight roughness at idle, or a slight change in exhaust tone. It was very subtle, and often undetectable without watching EGT or DPF temps with a ScanGauge or other.
I haven't detected a regen on my 2017 yet, but I only have 500 miles on it... Ford seems to have done a pretty good job at hiding the whole functionality for normal driving.
I used to obsess about letting regents run to completion, but not sure I need to do that any more. Frustrating because invariably, it would start an active regen 5 or less miles from my destination!
Old Jun 25, 2017 | 08:57 PM
191124x7's Avatar
191124x7
Getting the DPF% enabled was really eye-opening for me. I thought that no matter how full the filter, getting on the highway would kick off a regen; but I, like OP, have noticed that it never starts a regen until the sequence OP described above...95%...99%...then it starts dropping.
I made a lot of 'wasted' highway trips guessing that it was nearly full and hoping a regen would occur.
Another thing I noticed...I think I read here on another post that if your speed fell below 40 mph the regen would stop; but that has not been my experience. Twice, I've been on divided highways and had a regen occur...only to get stopped at an intersection...and as I sat at the light I watched the percentage continue to go down.
IMHO, nothing is going to start it until it's time; and if you keep driving your truck reasonably, nothing is going to stop it until it's done.
Old Jun 26, 2017 | 06:19 AM
Blwnsmoke's Avatar
Blwnsmoke
it won't stop when you get below 40. I've been in bumper to bumper traffic many times and the regent continues. What will get it to stop is putting it in Park. If high enough (%l, when you put it in Drive, it will start back up again.
Old Jun 26, 2017 | 07:05 AM
milkweed.gardener's Avatar
milkweed.gardener
It has been my understanding that the passive regeneration is always occurring. That in order for the passive regeneration to be effective the exhaust temperature needs to be high enough. That when the filter gets too full an active regeneration occurs and revs the engine to get the exhaust hot enough to clean the particulate filter. I thought I had seen somewhere that during an active regeneration the command module would inject small amounts of diesel just before the exhaust to help heat up the filter quickly, which I think this is why the manual says you might notice the exhaust tone change.
Old Jun 26, 2017 | 07:13 AM
Blwnsmoke's Avatar
Blwnsmoke
The engine does not rev more during a regen. It just dumps more fuel (about 1.5 gallons of extra diesel on a full regen). Anything around 675 degrees for egts will keep soot at about the same level. Anything around 700-750 will cause a passive regen (egts are high enough for a slow burn down).
You are not always in a passive regen.
Old Jun 26, 2017 | 08:56 AM
wfedwar's Avatar
wfedwar
Only negative I have seen to parking the truck in the middle of a regen is that one time I saw a bit of visible smoke when regen kicked back on the next time I drove it. Don't know what that was from exactly, but it was that one time when it reactivated regen . I used to worry about regen and tried to drive it out. I don't anymore. Just let it do its thing.
Old Jun 26, 2017 | 09:56 AM
milkweed.gardener
What do you mean by 'dumps more fuel'?
Does it burn more in the engine? or somewhere else in the exhaust?
> 'You are not always in a passive regen.'
So does the computer have to be in a 'regen' state for a passive regen to burn off particulates from the filter?
Old Jun 26, 2017 | 11:30 AM
Blwnsmoke's Avatar
Blwnsmoke
When in an active regen, it dumps fuel into the engine during the exhaust stroke. Adding the extra fuel during the exhaust stroke is what gets your Egts into the 1,100 degree range to burn the soot off (typical get when not active and unloaded is in the 450 degree range). I've played around with fill UPS and mpg over the last 3 years and have averaged between 1.5 and 2 extra gallons of diesel used for a full and complete active regen (full down to about 25% which takes about 23 miles on average).
A passive regen is anytime you are burning more soot then making. When I tow my camper (40ft 5th at about 13k) at highway speeds, I can get my egts to stay in the 650 - 700 range which maintains my soot level.
bldfrdblu
Nov 9, 2018 04:57 PM
Christian's1988Ford
2015 - 2020 F150
25
Oct 2, 2017 11:00 AM
Rafiki2cu
6.7L Power Stroke Diesel
30
Jun 28, 2010 08:41 PM
TwIsTeD OfF
6.4L Power Stroke Diesel
39
Jul 18, 2008 08:26 PM
HammerFX4
2004 - 2008 F150
21
May 3, 2005 08:53 AM
