bump feeling when turning.
Old Jun 24, 2017 | 03:00 PM
dthut's Avatar
dthut
hey guys,
79 f250 2wd.
when i turn right only, i can feel like a bump, bump, bump feeling right at my feet.
any clues what would be causing this?
wheel alignment issues maybe?
Old Jun 24, 2017 | 03:08 PM
PapaBearYuma's Avatar
PapaBearYuma
Do you have "larger than stock" tires hitting the tie rod or wheel well liner?
Jump underneath, have a helper turn the wheel, and inspect the steering gear, pitman arm, radius arms (and bushings) and tie rods.
Check the shocks, too
Old Jun 24, 2017 | 03:24 PM
dthut's Avatar
dthut
ya stock tires and wheels.
should i get the tires off the ground to do that?
thanks
Old Jun 24, 2017 | 03:26 PM
dthut's Avatar
dthut
i should ask discribe it better. it isn't happening at a certain point of the wheel being turned. the more i turn the more i feel it. it's a harder bump when i'm turning a hard corner.
Old Jun 24, 2017 | 03:37 PM
PapaBearYuma
It'd be easier with the tires off the ground, but make sure to properly support the vehicle. Jacks are for lifting-not holding-definitely don't get under a vehicle supported by only a jack!
Anyway, look around to make sure everything is clearing and nothing is binding.
Could be the steering gear too, I guess. I've heard they can develop problems in left turns and not right turns. Or vice-versa.
Old Jun 24, 2017 | 07:44 PM
lasermike's Avatar
lasermike
I'd also look at the tires
A broken belt or flat spot might not show up until the wheel tilts over in a turn.
Michael
Old Jun 26, 2017 | 12:22 PM
SlikWillie's Avatar
SlikWillie
I had this problem three years ago. It went away after I rebuild my gear box but didn't see anything wrong internally.
RGH2019KR
Apr 15, 2019 03:13 PM
Midnightride42
1997 - 2003 F150
Jun 9, 2012 12:16 AM
Mitch1407
May 6, 2011 03:08 PM
TOPFLOR
Jun 28, 2004 11:23 AM
adam frick
Sep 10, 1999 08:27 PM
