Turning problem
Old May 6, 2011 | 01:39 PM
Mitch1407's Avatar
Mitch1407
Turning problem
Hey,
Rotated my tires the other day because I thought they were cupping really bad causing the ssshhhakes. But now when I go around a slight bend around 45 MPH the steering wheel shakes like crazy and the ol' palm shaker is more like an arm shaker. Sometimes I feel it grab and really whip if you turn it past the shaking position.
Its really hard to describe I know, it feels like im just getting some serious wobble when i turn, I dont think its related to the tires. I think its got more to do with the front steering stabilizer.
Anyone have this problem? Im stumped...
Thankya
Old May 6, 2011 | 03:00 PM
clintbonnie's Avatar
clintbonnie
Had similar problems with original tires..Generals.. They were cupping badly on the front...with noise. Switched them for Michelins LTX's... about 3 years ago... problem solved..
Old May 6, 2011 | 03:08 PM
cps's Avatar
cps
First, it is probably not the SS. Second, jack up one wheel at a time and give a pull on the tire by gripping the top and bottom to see if you have any movement. If you do a ball joint needs replacing. Make sure your lug nuts a torqued right. Next you will want to have a friend start the truck and turn the wheel back and forth while you look at your tie rods and drag link, looking for excessive play. Roy
xjcamaro89
2004 - 2008 F150
20
Jul 12, 2009 06:20 PM
unrulee
Sep 14, 2008 12:25 AM
unrulee
Mar 5, 2008 06:17 PM
89302guthrie
Jun 13, 2007 02:27 PM
