1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 f250 front axle
Old 06-24-2017, 01:23 PM
FractureCritical's Avatar
FractureCritical
FractureCritical is offline
ok, I need some help here. Wasted ball joints in my front axle. I just spent three hours beating the hell out of the driver side to get it apart. The locking hub was seized and rusted solid into the wheel hub. The nuts on the ball joints were gone to the point that I had to use a cutting wheel to get them apart and get the knuckle off. I spent another hour trying to separate the wheel hub from the knuckle and failed at that, too.
I dont know that I'm going to win the fight with this thing. The question I have to ask is what other years interchange axles and/or knuckles with my truck. Some interchanges say the year break over is 2000, some say 2002, and I thought these things were same axle from 2000-2004. Any advice here would be appreciated
Old 06-25-2017, 12:07 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
So where are you now..What won't come apart? 2000 - 2004 should be the same dana 60.
The hub bearing wont come out? did you get the nuts off ok?
Old 06-25-2017, 01:05 AM
The Tiger's Avatar
The Tiger
The Tiger is offline
Some of the 250's came with the Dana 50 front. It will interchange but it is different.
Old 06-25-2017, 04:32 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
This is a 4WD?
The use of a ball joint press makes the job a lot easier (can be rented).
Take the knuckle/hub to a machine shop and ask if it can be pressed apart (if damaged while pressing you are no further worse off).
There should be an Axle I.D. Tag @ the front differential cover. This will I.D. the front axle asm (through use of the MPC) and give you service part info as well as info for Hollanders if you have to go that far.
Old 06-25-2017, 07:11 AM
FractureCritical
I'm not having a lot of luck getting anything apart. The Ford factory locking hub is fused to the wheel hub. That little retainer ring that usually comes off with two fingers? I had to get it out with vice clamps and a screwdriver. The locking hub itself will not move, even after an hour of beating on it with a rubber mallet and PB Blaster.
I was able to get the knuckle off by using a cutting wheel on the ball joints. There wasn't enough meat left on the top but to get a gun on itThis thing is a friggin nightmare.
Old 06-25-2017, 09:43 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
Remember the days of old when (when Knights were bold... ...whoops) there were grease fittings on all components?
Planned obsolescence.
Old 06-25-2017, 11:34 AM
FractureCritical
I blame a dual mixture of 50% magnesium chloride de icing bribe and 125% of bad materials and corrosion engineering on the part of Ford. Calling them criminally incompetent would be an understatement.
I'm slowly coming to the conclusion that this entire knuckle assembly might be trash because somebody tried to save $0.19 simplifying the locking hub design.
Old 06-25-2017, 01:21 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
many guys have had to crack and drill to get them out.
Old 06-25-2017, 06:11 PM
FractureCritical
as I get deeper into my box of wine, I've become increasingly determined to get that damn hub out and save the knuckle. I researched what you said, and it does look to be a common issue. Stupid Ford 'engineers'
Old 06-25-2017, 07:03 PM
GN1220's Avatar
GN1220
GN1220 is offline
Originally Posted by FractureCritical
as I get deeper into my box of wine'
There's your problem right there. You need beer to work on these trucks. LOL
Old 06-25-2017, 07:18 PM
FractureCritical
im quickly drifting into Maker's Mark territory with this truck.
Old 06-27-2017, 09:53 AM
FractureCritical
so after some internet and soul searching yesterday, I decided to accept the stock ford hubs for the crap they are remove them via violence. I bashed off the exposed portions of the hub with a 5 lb mallet and a big cold chisel. No baby hits here: I beat it like a punk that owes me money. After getting it down flush to the face of the wheel hub, I could pull out the internal locking sprocket which made room for the aluminum hub body to be beaten off the inner wheel hub surface. I drilled a few 1/4" holes down into the aluminum hub to make breaking it up easier. it was easy to drill.
back to the 5 lb mallet and the cold chisel and the rotten oxidized aluminum came apart in a few minutes of hammering.
I should have been pissed at having to waste the hubs, but it was oddly cathartic to be bash the crap out of them while thinking of the Ford engineer that designed these things. 70 years of screw cap hub locks working just fine, and some ******* ford engineer gets the bright idea to use a loose snap ring and an un-compressed o-ring to seal the assembly. yay.
still going back and forth on Warns or Mile Marker hubs. I like the price and the reviews on the MM hubs, but the Warns look like they have a better design for sealing.
Old 06-27-2017, 10:55 AM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Heat it till it's almost red. Let it sit until it turns back to iron color then hit it with water. This shock method has never failed me yet. You may need to do it more than once.
Be sure to assemble everything with silver anti-seize for future wrenching fun.
The fire wrench is your friend in the salt belt, so is anti-seize. A rose bud tip with a neutral flame works the best.
cgrandahl64
04-06-2009 09:54 PM
Trolex409
1997-2006 Expedition & Navigator
03-05-2009 03:01 PM
rustydailey
10-01-2007 10:35 AM
hotshot414c
02-26-2007 10:00 AM
DannyP
01-20-2000 11:02 PM
Quick Reply: 2001 f250 front axle
