Front axle questions
Old Oct 1, 2007 | 09:04 AM
rustydailey's Avatar
rustydailey
I was looking under my truck trying to figure out what a rattle was and grabbed the front axle at the u joint and just shook it. So I took the wheel off and disassembled the hub and removed the axle. When I looked at it there are groves in it so do I need a new one or will this one work? Now I'm trying to get the parts to put it back together. Is there a place to get a new axle end and all the hub pieces?
Old Oct 1, 2007 | 09:13 AM
blksiryder's Avatar
blksiryder
the groves may be a byproduct of the bad u-joint or wheel bearing and the axel just rubbing on somthing. if there not deep it should be fing but if you can catch your finger nail on the grove then have a shop check it out. you can find all the parts you need at www.quad4x4.com thats wher i got all my stuff
Ryder
Old Oct 1, 2007 | 10:35 AM
Alpine6's Avatar
Alpine6
Agree w/ above. Just do yourself a favor and change it all out while your in there and check your ball joints too. NOW IS THE TIME while it's all apart. I know from experiences. Yes, that's more than once!
Matt
