Sponsored by: Halo Lifts
3.5 Ecoboost gen 1 versus Gen 2
Old 10-31-2017, 10:21 AM
Terryd91's Avatar
Terryd91
Terryd91 is offline
The NA 3.7 and 3.5 are not direct injected, which is the main issue with long OCI as it causes oil dilution.
If anything intake pressure(boost) would help to push a valve open, which would reduce the stress on the cam. Unless ford jacked the spring rate up there should be less wear.
  #107
Old 04-05-2021, 12:23 AM
DHGxFallenAngel's Avatar
DHGxFallenAngel
DHGxFallenAngel is offline
Originally Posted by 93Cobra
You need to keep reading. There are wastegate problems, misfire / shutter (fixing with the weep hole), and cam phaser rattles. These are the same issues the gen 1 ecoboost was challenged with.
I had a misfire issue on my 13' f150 eb. This was caused by manufacturer spark plugs coming with incorrect gaping. Replaced all 6 spark plugs and all 6 coil packs while I was in there ( that was my 1st issue in 70k miles) and I never had that issue again. I feel I should mention it only misfired at high rpms when I really got on it.
While I was replacing this I did inadvertently knock off the top of my oil dipstick 😂 that's a me problem tho not a ford problem.
I have done an S&B oiled cotton air intake. UPR mega Catch can with a clean side seperator to help with coking on valves. I am in the process rn of installing a mbrp 4" cat back side exit kit, a 2.5" leveling kit in the front, 20" wheels and 33" m/t tires. Thinking of getting a tuner for economy tunes and reprogramming the speedo.
Love my steel body truck, it takes a beating and keeps on ticking. Nothing like those new aluminum ones I had awhile back.
(I have thought quite a bit about what it would take to swap a new 2nd gen ecoboost into my 13 screw f150 xlt, keeping my 6 speed auto of course.)
barry s
01-02-2009 03:33 PM
johnf350diesel
1999 to 2016 Super Duty
11-19-2008 02:49 PM
EXPLORE SPORT
05-19-2006 01:12 PM
Elynn_03
01-30-2003 12:47 AM
4x4_EB_Explorer
06-07-2002 01:12 PM
Quick Reply: 3.5 Ecoboost gen 1 versus Gen 2
