Horn not working
I hope I didn't mess things up worse than they were. When I took off the wheel I wanted to explore to see if the shift collar was an easy replacement as mine is broken where the shifter handle goes into the collar. It doesn't seem to be like it was before. I couldn't get the shift handle to pull towards me to put it in reverse/1st gear. I finally got it back together but I still can't move the handle to 3rd gear. Maybe when I move the truck it will go into gear?
You can get a replacement for that upper bearing. If you want to do it right, Carolina Classics will rebuild that column for you. The three speed shift tubes are no longer manufactured.
You didn't ask, but you can also get a replacement bushing for your shift lever there on the column where you have pictured your hose clamp. You can get that from Dennis Carpenter, among other places.
I put a copper BB under mine to make it work. I should replace it but they seem to expensive for what it is and none of the local parts places have them. One of these days I'll get a new one... But it works for now
The coil spring that is made as part of the brush breaks, the brushes wire snaps off, the insulator cracks.
C2OZ-13A821-A .. Horn Brush & Insulator Kit / Obsolete/Reproduced ~ 100+ available NOS
MCDONALD OBSOLETE PARTS in Rockport IN has 7 = 812-359-4965.
MILLER OBSOLETE PARTS in Binghamton NY has 11 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 74 = 800-543-4959.
Applications: Misc 1960/64 Ford/Merc Passenger Cars; 1965 Mustang w/a generator // 1961/66 F100/250 2WD; 1966 F100 4WD; 1967/70 F100/250; 1969/70 F350.
Note: Originally (1960/61), Ford sold the brush & insulator separately, but in 1962, replaced both with this kit.
Most of the repro parts sellers only sell the brush, so if the insulator is required, you have to buy a NOS kit.
C2DZ-13A809-A .. Horn Button/Horn Ring Nylon Retainer / Reproduced
This retainer has three tabs, when one of the tabs breaks off (typical), the horn/button/ring will not fit on the steering wheel properly, will fit catty-wampus.
C0DZ-13A813-A .. Horn Ring Rubber Pressure Pad / Reproduced
Located on the inside of the horn ring. When it flattens out, the horn will no longer blow.
Note: The coil spring used with the horn ring (C0DZ-13A807-B) is different than used with the horn button (C0DF-13A807-B).
C3DZ-3517-A .. Steering Column Bearing / Available from Ford.
1961/73 F100/250 2WD upper & lower / Misc 1960/66 FoMoCo Passenger Cars upper & lower.
Of these two, both are 3/4" diameter, but the hole that the shift lever retaining pin passes thru, is in a different place in B8S-7246-A .. than it is in C2OZ-7246-A
I can pull out the old one but the way I am finding things it could be the wrong one installed by a previous owner years ago.
I am going to order the new shift collar but that is also confusing. There are two listed with the same part number on at least one site but they are both different item numbers.
Applications: 1960/65 Falcon/Comet; 1961/66 F100/250 2WD; 1966 F100 4WD; 1966/77 Bronco; 1967/77 F100/250 2WD/4WD
Read post #10 again, I edited out the A/T shift collar, edited in the 3 M/T shift collar.
Does the shift lever bind up between 1st and 2nd gear?
Is the shift lever "spring" loaded? If it's not, it's supposed to be.
shift collars out there. The prices are all over the map.
Obsolete parts vendors, repro parts sellers can charge whatever they want. Ford dealers may be cheaper, because they're STUCK with it. So you need to shop around for the best price.
Should I definitely go with a genuine Ford NOS for this part?
Which would you rather have, a genuine Ford NOS shift collar made in the US or Canada? Or a repro shift collar made in China?
There is ONE 3 M/T shift collar, but Ford replaced the part number three times, so one obsolete parts vendor/repro parts source may list a different part number than another source.
D5TZ-7228-B = Last MSRP: $99.48; Dealer net cost: $59.69.
Not sure about the spring. I think it springs back but I'll have to check that part also. This thing is turning into a real nightmare.
