erratic hpop
Old Jun 23, 2017 | 11:23 PM
farmer ford's Avatar
farmer ford
erratic hpop
so i have been struggling with what would feel like a misfire in a gas rig for some time. tonight i borrowed an edge cts so i could watch different PID's in stock nothing was noticeable but if i tuned it up i could watch the injector control pressure drop just after every loss of power. this is what i expected but now i still don't know what to make of it. also the ipr tps stay steady and the engine oil temp is running at about 203. my mind leaned towards injector orings but iwould expect a more constant shudder where as this seems to be unpredictable. i look forward to hear all thoughts you all have
Old Jun 23, 2017 | 11:42 PM
ReBilld's Avatar
ReBilld
Could be a bad ICP sensor.
Old Jun 23, 2017 | 11:47 PM
farmer ford
thats the one on left head for hpop pressure right?
Old Jun 23, 2017 | 11:49 PM
ReBilld's Avatar
ReBilld
Yep. On the left head up towards the front.
Old Jun 23, 2017 | 11:53 PM
farmer ford
also boost never topped 12 lbs and ebp is always higher than boost by 2 or so. (according to obd) i dont have actual guage on it. all boots are tight and no signs of exhaust leaks from manifold to turbo witch was recently all removed and new seals during head gasket and studs were done
Old Jun 23, 2017 | 11:54 PM
farmer ford
is there a test or just swap and see if the problem goes away?
Old Jun 23, 2017 | 11:57 PM
ReBilld's Avatar
ReBilld
You can unplug it and see if it still does it.
Old Jun 24, 2017 | 12:01 AM
farmer ford
i was tempted to do that but couldnt remember or find the threads i had read in the past where that was done to see if it was a good option. are there any possible side effects while unplugged and how long is to long to run it like that?
Old Jun 24, 2017 | 12:15 AM
ReBilld's Avatar
ReBilld
It won't hurt anything to unplug it and you can run it as long as you need to unplugged.
Old Jun 24, 2017 | 12:24 PM
farmer ford
So ran this morning with the icp unplugged and cleaned the ebp tube which was plugged at the exhaust manifold. I still have the same symptoms I forgot to mention there is also a puff of black smoke if it cuts out really bad
Old Jun 27, 2017 | 05:41 PM
mcali2's Avatar
mcali2
Sounds like a cantz problem.
dchamberlain
Feb 12, 2016 05:08 PM
Tugly
Sep 20, 2015 09:00 PM
sportsdad
13
Jun 8, 2014 05:06 AM
morson82
Dec 26, 2010 02:27 PM
brooksbronco17
Feb 24, 2010 12:29 PM
