2012 F150 Back Up Sensor Issue
Old Jun 23, 2017 | 10:35 AM
F250GH's Avatar
F250GH
Just hit 70,000 miles and went out of warranty. The issue is the Heads Up Display periodically shows "Check Back Up Sensor". When this occurs the sensors do not detect, and this doesn't happen all the time. I did clean the lens on each of them.
The dealer wants $115 to diagnose the problem. The parts cost $154 each from the dealer.
I did find sensors on Ebay for a fraction of that. But how do I troubleshoot this issue?
Old Jul 5, 2017 | 05:27 AM
Eco12's Avatar
Eco12
For what it is worth, I had the same exact issue. It turned out that two of the sensors had failed. Luckily I had mine done under warranty, but you could always try purchasing one and swapping it for an existing one and see if the issue disappears. Then you could just move it to a different position if the dash error occurs again. This might be a slow way of diagnosing, but you should be able to save the dealer time component. Then, if the new sensor has been in all four positions and the error persists, you would have to introduce a second new sensor into the mix and begin the process of elimination again. Hope this helps.
Jag Red 54
2015 - 2020 F150
Feb 12, 2017 02:24 PM
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
OldFordTrk1
1997 - 2003 F150
Dec 8, 2006 06:46 PM
droptank
Escape & Escape Hybrid
May 15, 2006 12:10 PM
Rubicante
Apr 20, 2000 08:52 PM
