2.5" Carli Backcountry Help needed!
Just picked up the truck from having the Carli 2.5" Backcountry level installed on my 2017 F250 Platinum with the add a pac rear leaf springs. When measuring the distance from the top of the tire to the bottom of the fender wheel well opening I have 3" difference front to back. it measures 11" in the front and 14" in the back? The truck looks a little nose low, but not three inches, see photos below. The question is did they install something wrong on the rear add a packs? the rear end seems much higher than prior. I had them return all the original parts. Looks like they removed the factory overload springs, added the add a pacs and reinstalled the factory blocks. I'd welcome thoughts and ideas if something was installed wrong by the local shop. Thanks!
- ADD-A-PACKS: SuperDuties equipped with a factory 3-5/8" Block will require the 2" Factory Block [7C3Z-5598-L, 7C3Z-5598-K] to achieve a level stance.
You should reach out to a user named 'OCVELOMAN'. His name is Dan and he works for Carli. He can get you squared away quickly. Or call Carli first thing tomorrow.
You remove the block only for the full leaf kit. For yours you just need a smaller block. PMF makes some really nice fabricated ones, or you can order any block that has the integrated bump stop for whatever height you want.
Do you have a side pic of the truck. I'd like to see the stance. Edit: see it now, all the pics didn't load at first.
i would call Carli and talk to them before you start looking into different blocks. Their instructions of the the add-a-pack do not reference the 2017 SD, they only have '16 and older trucks listed.
I am curious as to the answer. I am interested in the add-a-pack, but do not want the truck any higher in the rear than maybe an additional 1/2-1". My truck has 1/2" rake with the Carli coils and stock F350 rear now
