steering box rebuild
Old Jun 22, 2017 | 01:42 PM
clark grizwald's Avatar
clark grizwald
How difficult is it to rebuild the steering box in a '54 F100?
Old Jun 22, 2017 | 02:15 PM
Rust Wrangler's Avatar
Rust Wrangler
Easy peasy with some basic tools. The new sector shaft bushings will need fitting to the sector shaft and the old worm gear will need to be pressed off the shaft and the new one pressed back on, unless you buy a shaft and gear assembly. Everything else is a cake walk.
Old Jun 22, 2017 | 03:51 PM
raytasch's Avatar
raytasch
Believe Nothing
Like said, it is a relatively easy job. Just make certain you understand each adjustment and the order in which the adjustments are made.
Old Jun 22, 2017 | 09:01 PM
firstrider's Avatar
firstrider
Did both boxes on the two '52's I have . You will be glad you did .It makes a tremendous difference .
Old Jun 23, 2017 | 04:07 PM
clark grizwald
ya its leaking and sloppy as hell, is there a kit you recommend?
Old Jun 23, 2017 | 04:40 PM
Rust Wrangler
Mac's has a kit, it's 48-371993 for 53-55.
Ford - Ford F-Series Steering Box Rebuild Kit, 1948-1960 - Macs Auto Parts
Old Jun 23, 2017 | 08:19 PM
Greg Rogers's Avatar
Greg Rogers
Originally Posted by Rust Wrangler
Wow. Those are expensive!
Old Jun 26, 2017 | 07:50 PM
3twinridges's Avatar
3twinridges
Bringing this back to the top again and adding a little here, I rebuilt mine and plan on packing it with corn head grease. But this thread made me realize I didn't pack the bearings with corn head grease like I normally would with a wheel bearing. Is that really necessary though with the steering gear bearings?
JB
Old Jun 26, 2017 | 10:57 PM
BlueOvalRage's Avatar
BlueOvalRage
That stuff is runny enough that it will work its way right into the bearings very quickly.
Old Jun 27, 2017 | 01:00 AM
Fomoko1's Avatar
Fomoko1
I just got a quote of $$445.00 Canadian plus 5% and 6% Canadian taxes for a complete rebuild kit, our currency isn`t anything to cheer about.
Old Jun 27, 2017 | 06:21 AM
firstrider's Avatar
firstrider
Early Ford store in Ca.!948 -1952 Ford truck steering box rebuild kit .7C-3503 RBLDKIT $199.0 Includes Timken bearings . This is the item that was used on my trucks. Am very pleased .
Old Jun 28, 2017 | 07:50 AM
oldmerc's Avatar
oldmerc
oldmerc
I also got the kit from the Early Ford Store in CA , I think the price was the same about 5 years ago . Kit install is pretty straightforward but you may need a machine shop to ream the bushings and press the gear off and the new one on .
wmcewan
Jul 1, 2017 10:48 PM
jvmcc
May 10, 2017 10:14 PM
tinman52
Jun 29, 2016 09:56 PM
dlb.motorman
Feb 4, 2015 08:48 AM
packrat56
Apr 13, 2007 02:51 PM
