Door seal question
Old Jun 21, 2017 | 05:37 PM
Phil Fleming's Avatar
Phil Fleming
Door seal question
I have a 78 F100 regular cab and I was wondering if anyone makes door seals that do not need to be glued in place?
Old Jun 21, 2017 | 05:50 PM
Roger Carter's Avatar
Roger Carter
I have read that seals from a '92-'97 will work, after they are shortened a bit. Haven't done it myself, but have heard that they work well. Apparently the '92-'97 seals have a metal insert and doesn't require using adhesive.
Probably can get a set for next to nothing from your local Pick and Pull.
Good luck.
Old Jun 21, 2017 | 06:56 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
80 and up seals will work.
Old Jun 21, 2017 | 08:14 PM
tndallas's Avatar
tndallas
94 worked for me.
https://www.ford-trucks.com/forums/1...r-seals-2.html
Old Jun 21, 2017 | 08:28 PM
lafermedavid's Avatar
lafermedavid
door seals
as mentioned 80 and up,I got mine through precision,very well made ,easy to put in
Old Jun 22, 2017 | 03:01 PM
Phil Fleming
Thanks for the help everyone, now off to the yard for a search.
dancraig
Dec 27, 2018 03:02 PM
jvmcc
Aug 12, 2013 08:06 PM
fyrbzrodding56
May 20, 2009 01:42 PM
WALFORD'S 56
23
Sep 27, 2007 07:11 AM
petem
Jan 12, 2003 01:52 PM
