Chintzy headlight wiring?
Old Jun 21, 2017 | 03:18 PM
Pele's Avatar
Pele
I just soldered in H3 headlight connectors to replace my 9007 bulb connectors, upgrading the front end of my Ex from the faded, yellow 2000 headlights to 2005-2007 XL Sealed Beam headlights. (Gonna sell my 2005-2007 Clear headlights, as I prefer the sealed beams.)
Man, I thought I'd find 14 gauge wire... The high beam wiring looked decently thick, at like 16 Gauge.
For the low beam and grounds, though... I think I've seen thicker wire in cell phone chargers, and those are rated at 2 amps.
You figure a 9007/HB5 bulb is rated at 55/65 watts for Low and High beam respectively. At 12 volts, that's 4.6 Amps low beam and 5.4 Amps high beam.
Welp... Time to start looking at building a wiring harness.
Old Jun 21, 2017 | 04:27 PM
pirate4x4_camo's Avatar
pirate4x4_camo
16awg is good for about 11 foot run drawing 6 amps.
https://www.wirebarn.com/Wire-Calculator-_ep_41.html
Old Jun 21, 2017 | 06:48 PM
Stewart_H's Avatar
Stewart_H
I used this for my headlights: 9007/9008/H13 Conversion Harness Pigtail Set
We have upgraded our pigtails to ceramic high temperature 9008 (H13) plugs. This pigtail will convert your 99-04 9007 headlight wiring to 9008/H13 so you can install 05-07 headlights.
Stewart
Old Jun 21, 2017 | 10:38 PM
ExplorerTominCO's Avatar
ExplorerTominCO
I upgraded the entire headlight wiring on my Expedition with a relay kit from Daniel Stern:
Daniel Stern Lighting Consultancy and Supply
Doing this kit gives your headlights power straight from the battery (via a relay) and not through the headlight switch. It made my lights noticeably brighter.
Old Jun 22, 2017 | 08:35 AM
Pele's Avatar
Pele
My Excursion used to be a State of Oregon Public Works vehicle. When I got it, I removed parts of an emergency lighting harness, but I kept it around somewhere...
There's a Code 3 model 710 WigWag that has a set of relays for the headlights and gets battery power straight from the battery.
I'm gonna put that back together... Minus the emergency lighting part, obviously.
Pele
Feb 29, 2016 09:49 PM
quincyj34
Nov 10, 2015 03:58 PM
lemasters f100
Oct 20, 2012 09:07 AM
fordtrucklover94
Jun 4, 2008 07:58 PM
krelvinaz
May 23, 2004 10:15 AM
