Tire balancing beads and sand.
I've got something like 750 copper coated steel BBs in each of my tires. They were smooth at speed but now that they're worn out with 40k miles I have some vibrations. When I was first told of this idea, I thought the guy was crazy. But, it started to make sense once the logic was explained. It is indeed a viable balancing option. If I recall correctly, dynabeads is the commercial product, they list recommendations on weight if bbs needed for various tire sizes.
Just my $0.02 USD worth
From experience, some tire/rim combinations "slip" on the balancing machine when the machine starts and stops. Due to that, the weights never get put in the right place. This is also compounded by the tire tech that doesn't do a final check spin after setting the weights. Some machines have a 'spider' that splines on the shaft and has fingers that hold the wheel securely.
Also, irregardless to what tire techs at the discount places will tell you, you have to have weight distributed to the outsides of the rim. You cannot accurately balance a wheel/tire combo with the weight stuck on the center only. Yeah, it's unsightly to put weight out front but it's accurate.
I learned this from a shop that balanced the wheel/tire combos for my various road course cars. They were balanced to 0 imbalance at 100 mph, something that took the techs not much longer than the discount d00ds. I also learned about smooth ride quality when I had my street tires done the same way.
I've spun a thousand tires and never had one slip that I didn't immediately see, stop, retighten and respin. A traditional balance machine measures the force applied while spinning at the axis. A better balance would be a road force where it also measures the forces with pressure applied at the tread.
Beads and sand? I doubt it's as accurate as inside and outside weights.
It's a knock off mud tire and you want it to ride like an expensive street tire? It's probably made out of round, after all with tires you get what you pay for.
I've heard of such a thing in 4-wheeler magazines when other balancing options failed.
One thing to look into: Counteract Balancing Beads | The only tire balancing product proven to improve fuel economy.
There are others.
There are others.
My experience with balance beads is they do not work and in my case, caused death wobble after hitting bumps at 70 mph. Atturos are knockoff toyo mts. Clip on weights at a competent shop is the way to go. Ive run a set of 285/75r16 toyo at2s well above the speed limit, still silky smooth.
Here's my tires and wheel set up. And yeah of course I'd rather buy toyos but when u need tires and only got $1100 u can't be picky and I need MTS living in the mountains I commute to the Ford dealership every day going 70 mph and the wobble comes and goes and it's just bad enough to shake my mirrors and dash but nothing crazy
