1969 f350 dually pickup project
Old 06-20-2017, 02:22 PM
69 dually's Avatar
69 dually
69 dually is offline
Just bought this a couple of days ago.
1969 f350 2wd originally a dump
360 fe, 4 speed, 80k, Long tubes - flow master h pipe & 40s, holly 500, mild cam (from what I'm told)
moddified camper 8' bed
leafs removed from rear + lowering shackles and f100 spring up front
..... Plans are to do some body work to get it looking decent (already have front fenders on order), repair inner fenders where hood hinges, paint original color, get it a little lower, and maybe pull the motor and trans down the road and rebuild or swap.
I do have a few questions...
1. What are the major differences from the 350 and 250 not so much appearance differences but suspension and chassis wise is it just different springs and rear end?
2. What are must dos to this motor (not so much for performance as dependability) ... The truck will be a cruiser maybe throw a bike in the back once in a while, i do have a heavy foot but know better than to run this low lugging motor much past 4 grand.
3. front has some negative camber from the shorter springs will drop beams correct this if installed with the current springs or will i need to cut a pie out of drop beams to achieve this (yes I want to go a little lower and no i don't want to put a front clip on this year).
4. I can't find a matching right side mirror for this anywhere and i know they are hard to find but does anyone have one they would sell? I also need rear shock mounts if anyone knows where I can find those.
Nick
Old 06-20-2017, 05:10 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1969 F350 2WD originally a dump.
All 1953/78 F350's are 2WD, F350's weren't available w/factory installed 4WD until 1979.
Do you want the complete mirror that comes w/the head, or just the mirror head (also available separately)?
These Western Junior mirrors were available either painted or stainless steel. The head should be approx. 6 1/2" x 9 1/2."
There are 21 painted mirror heads available NOS, 1 is located at Miller Obsolete Parts in Binghamton NY (607-722-5371).
Old 06-20-2017, 05:15 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Is that a chevy fender molded into the bed? Blasphemy!
Old 06-21-2017, 05:09 AM
f100today's Avatar
f100today
f100today is offline
I want this!
The following users liked this post:
Old 06-21-2017, 06:12 AM
Rasputin53's Avatar
Rasputin53
Rasputin53 is offline
Welcome to the 69 F350 brotherhood! You have the mirrors that have the single back mount instead of the top/bottom mount. I have this set on my dump truck and am going with the chrome Western Jr's that have the top/bottom mount. My originals are not in the best of shape. I can snap a pic and send to you. Awesome project BTW. And do you know what headers you have?
Old 06-21-2017, 06:13 AM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
I like it. Must do to the engine for me would be a Pertronix igniter ignition and a flame thrower coil. After that, I'd drive the $# it out of it
Old 06-21-2017, 07:05 AM
69 dually's Avatar
69 dually
Originally Posted by f100today
I want this!
Everything is for sale...
Old 06-21-2017, 07:11 AM
69 dually's Avatar
69 dually
Yea I know not for the purist, but I'm not one... I didn't mold them in the guy I bought it from did and said they were the only fenders that had a body line similar. I for one like the look... maybe I'll find a 12v cummins to put in to really **** people off
Old 06-21-2017, 07:17 AM
69 dually's Avatar
69 dually
The right side mirror had the top post cut off. I was told it was done so the holes in the top of the door could be used for a pipe rack which doesn't make since cause you wouldnt be able to open the door so i think maybe it was for a chain to hold the pipe down or a tie down point or something?
I like how the mirrors look on the thing and am really just looking for the right side bars or just the one that has been cut, if I can't find one I'll just make a top piece for the one I have and weld it on.
Not sure I feel like the guy said hooker LT but that could have been a bronco I looked at?
Old 06-21-2017, 07:25 AM
69 dually's Avatar
69 dually
I agree and did a quick search but couldn't find the part numbers or an install thread... I know its an easy job and something I should be able to handle but ya know can't hurt to read up on it.
Old 06-21-2017, 08:02 AM
TeachNlive4ever
I can't remember if it's part # 1208 or 1280
Old 06-21-2017, 08:07 AM
TeachNlive4ever
Distructions are in the box too. 351Clevland has some tricks and tips on the matter as well.
Old 06-21-2017, 08:21 AM
69 dually's Avatar
69 dually
EDIT: Figure out it is the 1281... just wondering which coil to go with I'm thinking the 40,000 volt one should be plenty? Also I will run new plug wires but should I run different plugs?
94windsor's Avatar
94windsor
94windsor is offline
Nick
Any idea how many leaves were removed? I have a 71 F-350 I want to lower. drop beams in the front and I want to get the rear down 4" to match. Planned on removing springs to help the ride too.
Old 06-21-2017, 09:13 AM
69 dually's Avatar
69 dually
There are 5 leaves left I would assume the top 5 also I believe he change out the shackles but not sure with what.....
That reminds me where can I get shock mounts for the rear mine are missing and I need shocks before the bouncing make me throw up.
Quick Reply: 1969 f350 dually pickup project
