Low budget leveling kit
Old Jun 20, 2017 | 09:03 AM
Blue6.2's Avatar
Blue6.2
When I bought my truck It had 2 3/4" of rake in the front, so a leveling kit was a must for me. I decided to go with a 2" kit since I do use the truck to tow.
I called a couple of shops in my area and it seemed $500 for the kit, install and alignment was the going rate. I stumbled on the motofab 2" kit on Amazon for $24.99.
https://www.amazon.com/dp/B017UZ6SXK/ref=cm_sw_r_sms_apa_Knsszb077ES6K
It's made out of billet aluminum (same as most of the more expensive kits). It is a very simple design and it is very simple to install. I did the install myself in a little over an hour in my driveway. I found a shop to do my alignment afterwards for $35 so I have a total of $60 invested in the whole process. This saved me $440!!! I feel like this is too good not to share with you guys interested in leveling your new trucks.
If you decide to go with a kit larger than 2" I would recommend installing a track bar relocation bracket or an adjustable track bar. Also install either new shocks or shock mount relocation brackets.
I think you will be fine without these on anything less than 2.5". I had a 2" kit on my last truck for 5 years (70k miles) with absolutely no problems.
After installing the kit and aligning the truck I have noticed no difference in the factory ride. I am still running the factory goodyears (for now &#128521.
Old Jun 20, 2017 | 09:28 AM
GoldenDomer's Avatar
GoldenDomer
Truck looks amazing. The stance is perfect.
Old Jun 20, 2017 | 09:36 AM
Blue6.2's Avatar
Blue6.2
Thank you, I am very pleased with how it turned out.
Top_Speed1's Avatar
Top_Speed1
Looks awesome!, and a great deal at that always puts a smile on your face
Old Jun 20, 2017 | 09:56 AM
shortride's Avatar
shortride
Looks good! I hope this doesn't turn out to be "you get what you pay for" sort of a deal.
Old Jun 20, 2017 | 09:58 AM
nbayless36's Avatar
nbayless36
Is your front axle still centered side to side? And did it come out to a full 2" lift on the front?
Old Jun 20, 2017 | 10:09 AM
Blue6.2's Avatar
Blue6.2
It did level exactly 2" in the front, my before measurements were 2 3/4" lower than the back now it's 3/4" lower than the back. The axle may be off by a 1/4" , it's so hard to tell with the naked eye. But it did align perfectly and still rides like new so I'm not very worried about it.
Old Jun 20, 2017 | 10:10 AM
RugbyRef's Avatar
RugbyRef
^^^Exactly what I would like to know!^^^
Old Jun 20, 2017 | 10:12 AM
Blue6.2's Avatar
Blue6.2
Old Jun 20, 2017 | 10:15 AM
Blue6.2's Avatar
Blue6.2
Thank you! It's just a solid piece of billet aluminum with a hardened steel bolt. Not much that could go wrong in my opinion.
Old Jun 20, 2017 | 11:02 AM
Tricon's Avatar
Tricon
This is exactly what I used while I wait for my coils. Its a great kit for the money. I added sway bar drops, bump stop drops, caster bushings and track bar bracket as well as 4 Fox shocks.
A spacer is a spacer. In fact I think these spacers are better than most in that they are bottom mount (so you can't see em) and they are aluminum instead of plastic. If you just have a mall queen I think this is a great option. If you plan to do any offroading, I'd go with an actual suspension lift. Either way, its $25 well spent!
Here's the actual spacer installed.
Old Jun 20, 2017 | 11:10 AM
Blue6.2's Avatar
Blue6.2
[QUOTE=Tricon;17273213]This is exactly what I used while I wait for my coils. Its a great kit for the money. I added sway bar drops, bump stop drops, caster bushings and track bar bracket as well as 4 Fox shocks.
Very nice set up, I plan on upgrading to the fox shocks later. I'm not very impressed with the factory Rancho's.
Did you go with the 2" or 2 1/2" kit?
Old Jun 20, 2017 | 11:14 AM
Tricon's Avatar
Tricon
2.5" kit. And yes the stock Ranchos are complete pieces of poo. With 1000 miles on em one of them wouldn't even decompress on its own.
Old Jun 20, 2017 | 11:17 AM
Blue6.2's Avatar
Blue6.2
Between the cost of these trucks and the Rancho reputation you would think they could do a little better! Lol
Old Jun 20, 2017 | 11:26 AM
Tricon's Avatar
Tricon
Yea, unfortunately I don't believe there's anything Rancho about those shocks other than the sticker. I'm not really a fan of Rancho shocks anyways, they tend to only last about 15-20k miles for me. I'd rather pony up for a real shock and just rebuild them for the life of the truck for about $10 a shock.
Nice lookin truck btw!
