Sponsored by: Real Truck
Forced Idle. Please Help.
Old Jun 29, 2017 | 11:10 AM
Mike1's Avatar
Mike1
Try watching this video and pay close attention to it at about 10:25 minutes.
This is my thoughts:
#1 new TB is bad or the TPS is bad.
#2 you didn't torque it down correctly and it's sucking air.
#3 you did not let it run long enough to relearn it's curve
#4 maybe try to disconnect battery for about 30 minutes to clear the codes, Just guessing on this last one.
Old Aug 4, 2017 | 04:09 PM
blacklab5's Avatar
blacklab5
Just wanted to follow up on my forced idle issue. Sent the PCM out to be checked and turns out there was a bad resistor on one of the boards. Received the repaired PCM and and all is well. Thank you.
Diesel 724
Feb 17, 2014 06:04 PM
jhayden
2004 - 2008 F150
Jun 7, 2012 09:19 PM
rscamaro305
34
Oct 29, 2011 03:28 PM
Evill Ed
Aug 3, 2004 10:02 AM
