351M fuel pump eccentric question?
Old Jun 19, 2017 | 11:21 AM
400v8f250's Avatar
400v8f250
Exclamation 351M fuel pump eccentric question?
Are the 351M fuel pump eccentric's just a 1 piece like shown in the picture? I'm seeing conflicting information as to that they may be 2 piece or 1... Hoping for clarification.
Old Jun 19, 2017 | 11:38 AM
mark a.'s Avatar
mark a.
That is a 2 piece. You are missing the outer piece.
Old Jun 19, 2017 | 12:54 PM
Filthy Beast's Avatar
Filthy Beast
Old Jun 19, 2017 | 09:55 PM
PapaBearYuma's Avatar
PapaBearYuma
I don't remember there being an outer piece when I changed the cam on my 351m. Does yours have a wear ring from the fuel pump arm riding on it?
I put a block-off plate on my 351m and run an electric fuel pump
Old Jun 19, 2017 | 10:09 PM
redcreekauto's Avatar
redcreekauto
The one piece is much thicker then what is shown. He is missing the outer ring.
Old Jun 20, 2017 | 11:21 PM
PapaBearYuma
My memory's not what it used to be. That's why I take pictures...
Old Jun 20, 2017 | 11:59 PM
400v8f250's Avatar
400v8f250
thanks all. I was able to find the other piece hiding away. Do you guys use any lubricant or high temp grease between the two piece eccentric? I know oil will flow thru, just wondering.
I know that the fuel pump arm is supposed to be lubed, wasn't sure about the 1st piece on the outer ring?
Old Jun 21, 2017 | 08:40 AM
ubereal2's Avatar
ubereal2
Yup, should be 2 pieces.
Unk Bob
Old Jun 21, 2017 | 10:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D0AZ-6287-A Outer & D0AZ-6287-B Inner .. 351C/351M/400 Fuel Pump Eccentrics / Obsolete
ranger140892
20
Aug 21, 2018 09:06 AM
EightGodzillas
Jan 12, 2015 04:54 PM
mamatried
Nov 12, 2014 04:32 PM
Buyerz
Mar 23, 2014 10:57 AM
scottie2hottie
Apr 18, 2008 11:12 PM
