400 / 351M fuel pump
Old Aug 15, 2018 | 07:36 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Does anyone know of a dependable, hopefully not Chinese made, mechanical fuel pump for 400? I've gone through 4 in a year. I may have to resort to an electric pump and a return type regulator. Not that those are American made
Old Aug 15, 2018 | 10:39 PM
flatbedfordguy's Avatar
flatbedfordguy
Unfortunately the overseas junk fuel pumps you buy at the parts stores can be hit or miss, and even the hits usually have a short life span. You may have better luck buying a NOS "made in usa" pump on ebay, I see them on there all time in the $15-25 range.
Old Aug 16, 2018 | 08:51 AM
ranger140892
Grumpy goat
Hmmm. Wouldn't happen to have a part number would you?
Old Aug 16, 2018 | 09:18 AM
Aaron-71's Avatar
Aaron-71
Rockauto.com
Carter M6978 - Mechanical fuel pump - $20
Old Aug 16, 2018 | 09:31 AM
ranger140892
Grumpy goat
Originally Posted by Aaron-71
We were talking NOS. I've been through a couple of Carter's. But thank you for looking that up
Old Aug 16, 2018 | 10:03 AM
flatbedfordguy
Here's one on ebay now NOS "made in USA" $19 OBO w/free shipping.....ebay item # 253768270905
Old Aug 16, 2018 | 10:12 AM
skyhawc's Avatar
skyhawc
I gave up and went with a carter Electric pump. It's been on the truck for a little over a year now without issues.
Old Aug 16, 2018 | 07:28 PM
ranger140892
Grumpy goat
Flatbed, thank you. I bought it. I don't think it's a motorcraft, but add says "Made in USA"...and we know how trustworthy ebay sellers are. I'll keep looking for spares. Thanks again.
Skyhawc, yeah that's on the *****-It List. I did try one of those clickety clack Holley mighty mites. It wouldn't feed a lawn mower carburetor. If I go back to electric, it'll be a higher end pump and I'll use a return type regulator.
Old Aug 16, 2018 | 07:38 PM
flatbedfordguy
I hope it works out for you, I know ebay sellers can be full of it but it does say "Made In USA" on the side of the pump though it is difficult to see in the pic.
As for the manufacturer I am not certain, the ad did not state the maker of the pump, but at least it's not Chinese!
Old Aug 16, 2018 | 09:43 PM
FORD~'s Avatar
FORD~
Facet fuel pumps are made in the USA. I’ve used one but it was in a priming capacity so cannot speak to daily use. I know many light aircraft use them however, so hopefully that speaks to some degree of reliability.
Old Aug 16, 2018 | 10:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes Facet has a great rep and quite...Electric Fuel Pump: How to Do It Right
Old Aug 17, 2018 | 05:59 PM
scottscott's Avatar
scottscott
Its not exactly cheap, but if you want to end your fuel pump woes without going to an electric, try this. I haven't needed to go to one, but I know people that swear by them, best mechanical pump they've used. RobbMc Performance Products - Ford 351C 550HP Fuel Pump
Old Aug 17, 2018 | 06:51 PM
Blue and White's Avatar
Blue and White
FWIW my 400 went through several parts store pumps some years ago before the major problem was discovered: old "non alcohol spec" rubber fuel lines that were getting sucked shut and collapsing. Replaced all the rubber lines and much better.
Old Aug 18, 2018 | 09:27 AM
4x4slik's Avatar
4x4slik
I have problems with fuel pumps and have put FI speced fuel lines, and still had problems.
Old Aug 19, 2018 | 03:49 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
what is happening to these pumps, just dying, leaking? just not performing?
