Seat compatibility
Old Jun 19, 2017 | 01:14 AM
kyle m's Avatar
kyle m
Seat compatibility
My new-to-me 95 has a bad bottom portion of the bench seat. I'm still getting used to this site, but is there a master list of seats for compatibility so I can check junkyards out?
The backrest of my seat is fine, but the bottom's all chewed up.
It is a full sliding bench
Old Jun 19, 2017 | 05:21 AM
mrollings53's Avatar
mrollings53
Seat frames are matched to the cabs they go in, for the most part. Regular and crew cabs have the same seat frames. Super cabs and Broncos have a different frame. I believe the seats themselves can go on any frame, but don't quote me on that. Years to look for range from 1987-1996 for any F-series, and 1997 for F-250HD, F-350, F-Superduty. However, the cab is unchanged from 1980, so seats from '80-'86 might work too.
Old Jun 19, 2017 | 10:26 AM
marv02's Avatar
marv02
If you have a bench seat and want go with the 40/20/40 the floor mounting for the 40/20/40 are different unless you want fab up your own brackets.
Old Jun 19, 2017 | 11:40 AM
kyle m's Avatar
kyle m
interesting. That'll make it easy hopefully to find seats. I don't foresee wanting to put custom seats in with new brackets. It's a home improvement truck so I don't care THAT much haha
Old Jun 19, 2017 | 11:57 AM
marv02's Avatar
marv02
I am sure you can go from the spilt buckets to a bench seat.
Old Jun 20, 2017 | 01:36 AM
Valpacer's Avatar
Valpacer
what years and models came with the 40/20/40 seats please? I'm in Australia so numbers are limited! How much different are the mounts?
Has anyone tried to fit 99-06 seats to an eight gen?
thanks!
Old Jun 20, 2017 | 06:47 AM
marv02's Avatar
marv02
The bucket part of the seat had 4 mounting spots each the center console has 4 self tapping metal screws that go through the bottom and screw directly to the floor.
The bench just has the outer mounts 2 on each side.
You have go under the truck and fab up some new mounts for the bucket seat mounts for this to work I would think the outside mounts would line up from the stock bench to the buckets so you have to make the inner mounts for the buckets and screw the center console to the floor.
Old Jun 20, 2017 | 01:47 PM
kyle m's Avatar
kyle m
I will stay with bench for simplicity then, unless I can only find buckets.
92-96f150lover
Jan 5, 2011 03:37 PM
Steve Christensen
1947 and Older Ford Trucks
Jul 23, 2010 07:56 AM
cowboyup1988
May 14, 2009 07:43 AM
59flatbedford
Jul 3, 2006 02:28 PM
zems
Jun 2, 2005 07:04 AM
