air bag warning light
It could be one of many things, a couple of the more common are:
1. Something has pulled a wire loose under the drivers or passengers bucket seat
2. One of the front impact sensors has gone bad there are 2 on the front.
Many times the front sensor goes out if water gets under the front plastic seal. These are not hard to change out. If the front sensor is bad you will normally feel a bump under the white and yellow plastic label on the the front of the sensor.
Fixed
finally home and got the truck to the dealership. They found a wire had lost connection discovered by checking for resistance in the wiring harness on the passenger side of the dash. Dash was disassembled to fix, which was simple reconnecting the wire, which somehow came loose. The side note to this was the fact the airbags were disabled during this period and would not have functioned. Glad it was fixed.
