Stupid trailer brake controller question
Old Jun 17, 2017 | 09:55 PM
Stalwart's Avatar
Stalwart
Originally Posted by K A M
Adaptive Cruise? Could that possibly activating if you have it?
i have it but it pulses the trailer pump in park with the engine running.
Old Jun 18, 2017 | 06:24 AM
senix's Avatar
senix
This has to be a faulty part somewhere. I would bet you will have to take the trailer and truck to the dealer and show them.
I would also bet they don't know what to do and will have to contact the hotline for a resolution.
Old Jul 6, 2017 | 10:04 PM
Stalwart's Avatar
Stalwart
UPDATE: After the tech discussed it with the Ford hotline, and after testing the truck, I took them the truck and trailer. I have a nice long pigtail so they were able to drive another SD truck along side and plug it in. SAME RESULT! Ford is on the case and they think a software patch will be required. Either the truck is sending out the wrong higher voltage signal than required OR even though the selected mode E/H is made, it is not actually switching modes. I had a new aftermarket brake controller and cable for my 2005 Excursion, they busted open the dash to gain access to the harness and my truck is now using that, until Ford finds the error and makes a patch. My trailer is useable again, that last limp home at 30,000 lb was no fun at all. It was funny, the tech set the gain a bit high and when I tapped the brakes, the trailer stopped the truck!
Old Jul 6, 2017 | 11:39 PM
rustyshakelford's Avatar
rustyshakelford
Glad they are on it. Correctly functioning elec/hyd disc brakes will ruin pulling a trailer for you. They make it so nice and relaxing to run
Brett
Old Jul 7, 2017 | 12:20 AM
ForeverFixing's Avatar
ForeverFixing
Good to know, I was thinking of converting my trailer to disk brakes. (elec/hyd) Maybe good to wait a bit.
Also was checking my schedule to see if you needed help. I'm down I-5 300 miles or so south of you. Looks like my truck would do the same thing. 2017 F-450.
you have a nice trailer too.
Old Jul 7, 2017 | 04:52 AM
senix's Avatar
senix
Thanks for updating us on the yet unresolved issue.
So the question will be, does everyone else need an update as well.
6door74
Nov 1, 2017 09:58 PM
Tugly
32
Oct 1, 2017 09:52 PM
brkncly
6.4L Power Stroke Diesel
Oct 25, 2012 01:18 PM
buba 11
All Things Towing
15
Feb 21, 2012 07:21 PM
Monsta
Sep 9, 2005 11:18 PM
