E4od to aod back to E4od
Old Jun 15, 2017 | 03:27 PM
Bramoutar2's Avatar
Bramoutar2
So I recently purchased a 1993 f250 5.8l for about 300$, but here's why lol the tranny has been having some problems so I went to change the fluid. Upon dropping the pan I immediately realized there was a AOD tranny in the truck as opposed to the e4od. From my understanding the aod doesn't require the harness plug from the e4od but it's still there. Would this give me much problems to drop a e4od back in it?
Old Jun 15, 2017 | 03:46 PM
Bramoutar2's Avatar
Bramoutar2
Well really what I'm asking is, was there any cables that would have been swapped with it and also the driveshaft length. Any info will be greatly appreciated!
Old Jun 15, 2017 | 04:31 PM
Conanski's Avatar
Conanski
Is this a 2wd or 4wd truck?
Does it have a TV cable attached between the trans and throttle linkage?
The E4OD is longer so it is likely a different driveshaft would be required.
Old Jun 15, 2017 | 06:45 PM
Bramoutar2's Avatar
Bramoutar2
its a 2wd and yes the cable is there
Old Jun 15, 2017 | 07:16 PM
Conanski's Avatar
Conanski
So what problems are you having with the current trans?
Old Jun 15, 2017 | 08:10 PM
Bramoutar2's Avatar
Bramoutar2
its been slipping and not catching high gears and there there was a few big chunks of plastic? In the tranny pan, plus I've heard the e4od was able to hold more power. I like going with original set ups and I doubt I'm going to find another one with such low miles so I want to get all the work done now so it can last me a long time.
KaoticCreations
Jan 24, 2012 04:42 PM
bowmn01
Mar 11, 2009 06:22 PM
currituckF150
Jul 22, 2007 10:28 AM
turboguy
Mar 13, 2005 04:36 PM
javi2001
Aug 20, 2003 06:01 PM
